Question about Bose in-ear headphones - Black with black/white cord
Opening bose on-ear headphone speaker's cup
The left speaker of my Bose on-ear headphones is intermittent. I know the problem is not the outside cable, it come from inside the cup. I tried to open it, but after removing the foam and the two screws hidden behind it, there's steel something preventing me opening the back part. I'm not sure if it's a hidden screw or a clip, I'm a bit afraid to use strength. Any idea on how to open them?
Thanks for your help,
Louis-Philippe Giroux
There are four screws that hold the cup together. Two at the top and two under the foam that goes between the ear pad and the plastic cup. Once I removed the four screws the cup and speaker came apart with no problem. Of course I did not see any issues with the soldering, so I have a bigger problem.
Posted on Mar 09, 2011
Apparently there are screws hidden in the small foam ring covering the plastic (not the earcushion). Try it removing the foam and tell me how it goes!
Posted on Jun 26, 2010
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
My headphone, once side where the ear cup joiner with the top bit was broken. Can I get it fix? Thanks
Call Bose 1-800-999-2673 they sell replacment ear cushions for the QC3 I paid $38 for two.
Nov 28, 2011 | Bose QuietComfort 3 Acoustic Noise...
Hello, I just got a Bose QC3 on eBay. It works fine except the cable which is not the original one but a one from T'nB and the left earpiece has a very annoying whistling noise when I press it or even...
i would buy a new ear cup.and a new battery. and perhaps a new cord.
i had a problem w/ my ear cups and i noticed that when i bought the new ear cups the sound was better.
i also read that if the battery got alot of usage (4 plus year) then the whistling noise comes from that. i'm starting to have the same problem. i have had my headphones for a long time. i think like anything else that operates on batteries its time to change it.
Mar 06, 2011 | Bose QuietComfort 3 Acoustic Noise...
I have a set of QC3 headphones from BOSE and the left ear has become intermittent, I know it is the jack on the headphone because I replaced the cable and same problem. I can't seem to get the ear peice...
this is what you do its the same thing that happen to my crysler aspen car the earphone wasnt like it was suppose to be it was staticing up and i know whats wrong just take it back to bose and they should replace it
Jun 28, 2010 | Audio Players & Recorders
How can I fix an intermittent sound problem on the left ear piece of the Tri-port on ear Bose Headphones? If I take the ear cushion off and touch the speaker inside the ear piece on the headset using a...
I have the same problem. The first one that I bought last 1 year. I bought another one and the same problem has appeared today. I think this is because they are assembled in China. Cheap and low quality manufacturer that is sold at very high prices.
Apr 01, 2010 | Bose on-ear TriPort Headphones
My bose headphone have blown
If the cord is damaged its not impossible, if the driver inside the ear cup is damaged its not worth trying. email me if you need a hand. n_raven99(at)hotmail.com
Mar 28, 2010 | Bose TriPort Consumer Headphones
Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Mar 17, 2009 | Bose in-ear headphones - Black with...
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
Bose  in-ear headphones - Black with black/white cord Logo
1,591 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
