Question about Grohe Classic Kitchen/Bar Faucet 31.057.000...
How do I remove the handles from the faucet? I cannot locate a screw. Thanks.
  • carol379 May 05, 2010
    Thanks for getting back to me. Turns out they just snap on and off; No screws.
  • 349 Answers
Does it have plastic or metal handles some have caps on top covering screws that hold handle on faucet.
Posted on May 05, 2010
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
SOURCE: how to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
Posted on Oct 12, 2008
  • 235 Answers
SOURCE: The faucet handle has become stiff to turn off and
The handle has build up in it but should come off eventually. Sounds like a dry o-ring seal. You can purchase a kit for your model without having to replace the whole unit.
Posted on Jul 05, 2009
SOURCE: Remove belanger one handles shower faucet cartrige
Please contact Bélanger Customer Service at 1-800-361-5960 with your product number or view our website at www.belanger-upt.com to find your model number.
Posted on Dec 15, 2009
How to remove thet trim on a t6520 bathroom faucet handle?
Most moen handles and trim are secured by an allen set screw located right under the handle by looking at the picture you supplied. Once the set screw is loosened the handle can be removed and then the deck escheon usually screws off. Most of the time you do not need to remove the deck cover to get to the valve cartridge.
Sep 08, 2014 | Moen T6520 Icon Two-Handle Widespread...
I am trying to fix a leaky danza single handle bathroom faucet. I cannot figure out how to remove any part of the faucet from the top to be able to change the washer.
There is a allen set screw on the handle it may have a cap over it locate it and unloosen screw and remove handle then un screw bonnet nut then replacement kits available at most hardware,home improvement,or plumbing stores take note of how the parts are removed so to reinstall the way they came out.
Jun 05, 2011 | Danze D203112 Melrose Single Handle...
I have a Blanco 157-081-ST Single handle, satin finish faucet that leaks. I'm trying to get to the cartridge but don't know how to take off the handle. I've removed a single screw on the handle body but...
If the screw you have removed is a set screw then you shuold be able to remove the handle. If it has been on there awhile you may need to pry on it with the handle in the full open state. Use something that will not mar the handle.
Feb 12, 2011 | Blanco 157-081-ST Modera Kitchen Faucet...
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
Cannot remove handle. Allen wrench receiver is stripped. Are there any other options? Thanks!
There is a home cleaning product called the The Works which will loosen the corrosion around the screw. Then use a screw extractor tool. You can find one at most hardware stores and home centers.
Another solution would be to call Moen Customer Support and ask for a new handle and repair parts for free. The faucet should have a lifetime warranty. When you have the new faucet parts in hand, literally cut the handle off the faucet with a hacksaw or drill the screw out to remove the handle.
Sep 07, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
How do I remove the bonnet nut from a blanco 1-handle faucet (like their "classic" model?
If you mean the top faucet handle, there is a small round plastic cap. You need to remove this and then remove the grub screw, handle will then pull off. Hope this is what you meant, if not post again. Thanks Paul.
Aug 30, 2010 | Blanco Classic Single Handle Faucet with...
How do I replace the spring and rubber seal
First turn water off to faucet and remove the screw that hold's the handle in place. They may have a cap on the handle to remove to access the screw.
After screw is out the handle should come off you may have to wiggle it a little to get it to come loose. Next you will have access to the spring and washer for that stem.
It should be located on the bottom of the stem just remove it and replace new ones back in place.
Some have sping's and seat in the body of the faucet if not located on the bottom of the stem.
Jul 13, 2010 | Delta Faucet 2530CBLHP/H25 Innovations 4''...
How to adjust the rotation of handle from hot to cold is centered
look for a small cover plate on the back of the handle. Pop it off with a flat screw driver. Inside should be a screw to remove the handle. remove handle and re install to desired location
Jun 09, 2010 | American Standard Kitchen Faucet 6310 020...
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Grohe Classic Kitchen/Bar Faucet  31.057.000... Logo
639 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
