Question about Kenmore Dryers
Dryer was working fine. Wife put another load in and dryer will not start at all.... Suggestions please??
  • bpalmer_ashe May 02, 2010
    Yes... it was infact the thermal fuse. I checked by over riding and worked fine.... ordered a new fuse.
  • Kenmore Master
  • 19,396 Answers
Hi.
Trip the circuit breaker or disconnect power cord for five minutes, so to reset the appliance.
If there is no power at all, reach the main outlet and the power cord and check them out if possible. Also check lint filter and replace the thermal fuse.
If the dryer is turning on but does not cycle, then replace the thermal fuse, then test the door switch, and finally go for the timer board.
The timer control board is expensive and control board failure are difficult to diagnose.
For this reason the timer board is replaced only after testing all other parts.
Test the door switch and on wiring harness/connectors to the electronic control board.
The door switch can be tested jumping its contacts.
If the main switch is not integrated on timer pcb, it can be tested reading ohms or jumping the switch, then turning back on circuit breaker.
Wiring harness and connectors are tested reading Ohms between two points to ensure that there is continity.
This operation must be done with power not connected.
If there is no problem concerning the wiring, door lock and timer, test quickly the heath group , motor, and rest of the wiring to ensure that the problem is not given by a contact that get lost at random times, then proceed in replacing the timer board.
To find parts you can use the links listed here: Parts and diagrams.
Some of test described must be done by a trained technician.
If you need to call a technician, use the phone number listed on the owners manual or see Fixya directory.
Regards
Posted on May 02, 2010
My wife dried a load of clothes took those out put in another load,dryer would not come on?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore 62602 Electric Dryer
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer won't start
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 07, 2010 | KitchenAid KGYS700LQ Gas Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Magic Chef Dryer model # CYE2000AYW
ck the thermo fuze and clean out the vent going out side ck the breakers to dryer
Mar 05, 2008 | Dryers
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
