Question about Whirlpool Duet GHW9150P Front Load Washer
Won't pump out water. no kinks or plugs. comes when vac is attached
  • 5,911 Answers
Have you checked the drain pump reservior? Something could still be obstructing the pump impeller and restricting it from turning. The following link explains how to check the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you have verified that the pump and drain lines are clear, you may have a failed drain pump. It does not take much to damage the small impeller and/or motor in these pumps. The following link explains how to replace the pump (if required):
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on May 02, 2010
Shop vac is not pumping out water just fills the canister
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here: https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is not kinked at any point along the line from the vacuum to the outside. If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
Sep 08, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
The pump lose prime when we vacuum
The reason the pump will lose prime anytime is because insted of the pump pulling in water, it is now pulling in air from some source. When you set up the pool to be vacuumed, you must be sure to prime the vacuum hose with water before inserting the vacuum hose into your suction. The easiest way to do this is to:
1. attach vac.head unto the vac.pole and 1 end of the vac hose.
2. holding on the the other end of the vac. hose so it doesn't get away from you. slowly lower the the set up into the pool and make sure the pole doesn't get away from you either.
3. now you will notice part of the hose is filled water and part of it is floating ontop of the water with air still in it. Now while sitting on the edge of the pool, pull the hose toward you to where you think the part of it is now full of water. than slowly feed the rest of the hose, hand over hand until the end of the hose and you will see water come out the end, the hose is now totally full of water.
4. This is the tricky part, cuff your hand over the end of the filled hose and with the pump running plug the end into the suction, re: skimmer or suction port.
At this point you might have induced some air into the system and the pump may lose prime or start to lose prime. Go over to the pool equipment and if present, bleed the air out of the filter.
Hope this solves your problem.
Jun 18, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
LG washer getting an OE error. I have opened the pump and drained the water as well as ckeaned the filter...still not working propperly.
OE means your machine has failed to drain within 10 minutes. There are a few posibilities. Your drain hose could be kinked or clogged causing the machine not to drain. Try using a shop vac to remove the water from the end of the drain hose. If a shop vac won't **** out the water either, you have a clog somewhere ing the drain hose, of the hose from the tub to the pump. If it will drain the water you need a new pump. If there is no water in the machine then the problem is either the pressure switch, the hose going to the pressure switch, of the control board. The pressure switch is on the back by the control board. You will see a black rubber hose going attached to it. Remove it and see if you can blow through it. If you cant it is clogged somewhere. If it is not clogged then the most likely cause is your pressure switch and next the control board.
Jan 30, 2011 | LG WM2101HW 4.0 cu.ft. Washer
I am getting a F21 error how do I fix it
that's a slow drain,take the bottom panel off,if you have a wet dry vac your gonna need it,put towels under and around the pump,unscrew the middle of the pump slowly,when the water starts coming out **** it up with the vac until it's drained.if there's any water in the tub **** that up first,when it's drained remove the center piece and clean out the pump,feel around in there and make sure nothing is in the pump,put it back and start it,if it still doesn't pump most likely you k.o.ed the pump and you'll have to replace it,also make sure there are no kinks in the drain line,press the pause cancel button twice to clear the code,if you need more help let me know,good luck
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Water is not draining? thank's
there are a couple of things that could cause this issue.
1. is the drain pump is faulty
2. the main control board is faulty
3.there is some kind of object stopping the pump from turning
4 the wiring to the pump has become dislodge or loose.
5 there is a blockage in the drain hose from the pump
6 if you have a wet dry shop vac disconnect the drain hose from under the sink and attach the shop vac to the hose and try and remove the water.
If the water drain easy then check in the pump for something that could be stopping the impellar wheel or faulty pump.
If no water comes out then there could be a grease plug blocking the hose you can use a hair dryer and heat the area of hose the grease plug may be in to remove it. good luck i hope this was helpful for you
Feb 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Losing pressure 2-3 min vacuum hose is attached to skimmer
de filters clog very fast i suggest put vac in pool put hose over pool attach a wet vac to get water out of hose remove wet vac and vac saves de and water
Jul 09, 2009 | Hayward 1HP Super Pump II Inground Pool...
My steam vac won"t **** up the water
Check the hose and make sure it is clear of debre and there are no kinks in the hose.
Aug 28, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Our GE Profile Deluxe washer is not draining
Your post says "drain hose is kinked". I assume you meant NOT kinked. You didn't leave a model # so it's difficult to advise. If it's a top loader set it to spin and listen for the drain pump sound. If you hear just a dull hum it's probably stuck with something in it.
Use a shop vac to get the water out. Pull the front off and remove the hoses from the pump. Look into the inlet and you'll see the object.
Jan 06, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
