Question about HP OfficeJet 7410 All-In-One InkJet Printer
Unable to send a fax
I am not able to send a fax from the HP Officejet 7410 all in one.
    Scholar:
  • 141 Answers
Is your fax correctly plug in the outlet line of the wall and the same in the back of your fax....????
Posted on Mar 25, 2008
The message prints out from my HP Officejet 7410: A communication error occurred during the transmission. Result Error 232* It was working fine before, now it won't fax 2 pages.
Actually Error 232 is mostly because of the Remote machine still we can try one thing in your machine ie - we can disable Error correction mode
How to disable it?
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
Try to send fax now .. It should work
Please Vote for me if it works
Jan 04, 2011 | HP OfficeJet 7410 All-In-One InkJet...
Does magicjack allow the hp officjet 7410 to send and recieve faxes
You should be able to send and receive faxes with the majic jack.
Nov 01, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Office Jet 7410 printer copies, fax are black
If you make a copy and it is black, either the ccd (reader is bad or the lamp is out) either is the end. Take it back to staples if you can.
Make sure you unplug it for about 1 hour and plug back in and try a copy.
Apr 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Can't fax
Can you send faxes to a local number? If you can the problem is likely to be that there is no long distance carrier set up for your new VOIP service. You could also try using a regular telephone connected to the same jack as the fax uses to try dialing a long distance number, this may give you a hint as to what's wrong. You should also contact Comcast tech support about this problem, the VOIP box may not be properly configured for long distance service.
Carl
Dec 04, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp 7410 all in one (fax)
I have to order a thing from the dsl to block the noise. I'll let you know what happens, Thanks for the hp booklet on line. I had some other things wrong and it really helped me.
Alli
Jun 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Whizzzzzing sound and will not send fax.
The problem is the power supply try to plug to different outlet and then send a fax if it fails then its a power supply fault please change it.............
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 prints OK, but copy and fax comes out black all but 1 inch
The problem is on the scanner...
You have to change "scanner assembly". But... here in Greece this unit has not spare parts.... The repair procedure is "unit exchange". You have to contact HP Service in order to inform you if they can change only the scanner assembly and not whole unit... You can call telephone support.
Apr 07, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp officeject 7410 fax
Check to make sure all the phones attached to that phone number are on the hook.. sometimes an answering machine can create a problem also.. if you really want to check the printer / fax machine out, just remove all the phones that exist on that phone line and leave the fax machine connected. once all the phones have been removed and the 7410 is still acting up, you might have a bad fax card in the printer.
Mar 21, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Fax not answering or receiving
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&lc=en&cc=us&dlc=en&product=391194&rule=44610&lang=en
Visit the HP Support and Drivers Home page .
Jan 24, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
89 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
