Question about Garden
Kohler CV15S on a John Deere LT155 smokes alot. I pulled the head off to check the cylinder. The cylinder looks perfect but the head gasket looks as if it has had blow by between the exhaust valve and the cylinder. Could the engine be pulling oil into the cylinder on the down stroke? This is a verticle shaft engine and the oil return from the overhead valves is in this area. Does this sound like I am right. I don't want to have to do a rebuild.
I also have a John Deere LT155 Garden Tractor, and 'I have issues with white smoke and cannot get it started. I have detected gas smell in the oil. Quick call to a JD service centre told me it was likely a head casket. If the smoke is white, then that is likely your problem.
Posted on Sep 23, 2010
Have a john deere LT 150 Automatic with kohler cv15s engine.just did a head job on it and when i go to start it will run a few secvonds and quit,any help appreciated
see if it is getting fuel full time that would be the first thing to check of course .I like a clear fuel line so I can see it flowing
May 11, 2015 | John Deere Garden
Why will engine not start.
first make sure battery is fully charged and in good shape. Be sure pto is off and brake/clutch pedal is depressed. If still nothing then check fuse. After that its likely a safety switch or bad connection.
Aug 03, 2014 | John Deere Garden
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Where are the spark plugs on john Deer 7 speed 15hp mower
it is to the side of the tin valve cover on the front of the engine
Jun 11, 2012 | John Deere Garden
Hi i have a LT155 JOHN DEERE 15 HP c-series ridingmower the kohler won't start seems like the lifters are pumping up and holding open the valves. so i pulled the head and took the lifters apart and...
if the valves are working properly and good connections and battery, i would check to see if the compression release is working. i have one in the shop that the release came apart in the engine.
Nov 22, 2017 | John Deere 420,1020,2010,2020,2510,2520...
15hp kohler in my john deere lawn tractor 1999 modle LT155 it smokes now after sitting for a 1-2 yr
If the smoke is blue you are leading oil past the seals, if its black you are running a rich mixture. since its been sitting around for a while you may also have a lot of varnish buildup in the cylinders which will take a while to burn out and will smoke until it does. If its blue the engine needs new piston rings, not terribly difficult, but not quick fix.
Jun 08, 2011 | Garden
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Oct 14, 2009 | John Deere Garden
Garden Logo
1,411 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
