Question about OKI MICROLINE 320 Turbo Matrix Printer
Okidata ML320 feeding blank sheets
We have a Okidata ML320 used for printing continuous forms. We are using the rear feed, page length is 11". We have it hooked up as a parrallel printer. We are emulating a IBM. This printer is fairly new and has done this since day one. The printer feeds a blank sheet of paper between each page printed. Is there a fix for this?
  • Anonymous Apr 03, 2008
    we've got okidata 395 and we also use the rear feed. The printer feeds a blank sheet of paper between each page printed...
    Habit-Forming:
  • 40 Answers
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Posted on Nov 29, 2008
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Problems with Printing Special Size Forms
you have to chk the setting on the print setup.
Jul 04, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
Jan 24, 2010 | HP Photosmart C7280 Printer
After Print job the printer skips and goes to next tearoff
check you manual, set the printer back to default. or it might be with the program your trying to print with. try print a test page using your driver. if it still the same. uninstall and reinstall it back to your computer to restore it to its default value
Oct 05, 2009 | Matrix Okidata Microline 320 Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
IBM 4232 Printer Problems
in the PRINTER SETUP menu there will be FORMS DEVICE
select and set
Continuous Forms — F1 or F2
Dimensions
Forms Min Max
Width 3in - 15in
Length 3in - 14in
Nov 05, 2008 | IBM 4232 Matrix Printer
Okidata Microline 320 Turbo Printer - forms don't maintain registration
On older printers, tractor feed edges separate from the page while printing. Sometimes this can be a fluke, but other times it may point to a mechanical problem. Try taking the paper out of the printer and hitting the form feed button a few times. Watch the printer’s tractor feeds to make sure they are moving and are in synch with each other. Some printers use belts to move the tractor feeds and, over time, these belts wear, break, become smooth and slip, or become misaligned.
Environment can also contribute. Paper stored in a warehouse can weaken in intense heat or moisture. Carbon copy paper will especially cause this type of problem as one sheet's feeder edge can break away from the rest and peel slightly back. This will in turn slow the feed on one side as the edge buckles slightly under and may even skip to release pressure causing major alignment problems.
Sep 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
656 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
