Question about KitchenAid 24 in. KUDK02CRBS Stainless Steel Built-in Dishwasher
The dishwasher dies in the middle of a cycle. It
The dishwasher dies in the middle of a cycle. There is standing water at the bottom of the washer. It would not restart no matter what I do. I double check the electrical, and there is no problem with the power source, please tell me what to do?
    Genius:
  • 1,036 Answers
You really need to find out if the unit is heating or not.
It is possible that it will Rinse, Pump out, Fill, then just sit doing nothing if either the heating element is faulty or one of the two thermostats are faulty.
Unplug and turn off supply before looking at these items with a multimeter for continuity.
Posted on May 02, 2010
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
Water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not pumping into dishwasher
I first checked the water valve in the dishwasher. It was working properly. The overflow or water level sensor had become stuck in the 'high level' position, thus telling the washer that it was already full of water. I corrected that and it began working properly. As for water in the bottom of the dishwasher that didn't seem to be draining completely - I turned the timer to a point in the cycle where it would drain, making sure I turned the washer off before it cycled back to the 'fill or rinse' cycle. I think the water had accumulated because of the timing of the cycles getting out of sync with the water level in the washer.
Jan 06, 2009 | Dishwashers
My dishwasher quit running in the middle of it cycle like there is no power going to it..... there is water standing in the bottom of it and i cant get the washer to come on or anything.... could it be...
it is simple to repair. you need a thermal fuse. take the control panel off and right where the control board is you will see the thermal fuse. you can either replace it or just splice the wires. let me know if you need further help
Nov 30, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
KitchenAid 24 in. KUDK02CRBS Stainless Steel Built-in Dishwasher Logo
129 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
