Question about Canon ZR85 Mini DV Digital Camcorder
Windows 7 does not recognize Canon zr65 connected w/ firewire
Did everything according to manual. I plug in the camcorder hoping to upload the video to MovieMaker and the camera is not recognized as a device from my new computer system with Windows 7. This is a new camera to me and has never been connected to any system before. I have been to the Canon site and downloaded the driver.
4 Suggested Answers
Malcg
  • 32 Answers
SOURCE: Downlading onto Laptop
Firewire and USB are not the same things
You will need a Firewire host adapter installed in your PC - such as Q-Tec PCI card (IEEE 1394 compatible) which comes with software / drivers
Good luck
Posted on Apr 13, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Camcorder not recognized
You need software to recognize it. Do you have video editing software in your computer?
Posted on Jun 30, 2008
  • 497 Answers
SOURCE: Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 15, 2009
I have an older canon mini tape camcorder and my mac pro wont recognize it for uploading
You could try the cannon website to see if there are any driver updates for your model. Cannon may have a users forum, which you might be able to pin point the problem there, If that doesn't work try the mac website for updates etc.
Feb 09, 2013 | Canon Ultura Mini DV Digital Camcorder
I have sony trv33 and windows 7 using firewire 1394 port and cable computer does not recognise camcorder when turned on
Your camera will not be recognized when you connect it via firewire. To transfer the video from your camera to your computer you will need a video editing program that is able to capture video from camcorders connected via firewire.
You can try Windows Movie Maker for Windows 7. Alternatively your can search through the internet to find a more advanced video editing software.
Regards,
nicolasiac
Feb 03, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Unable to Load software
Did you try uploading using a firewire card and firewire cable? It is an alternative to USB and is the most preferred way of transferring video from the camcorder these days. Also did you try uploading the video using windows movie maker? COnnect your camcorder to your computer and press the capture from camera option to capture the video on your camcorder to your computer. If you have already tried everything then the simplest way to transfer is to remove the 1.5" hard drive connect it to your computer(your computer should have SATA connector), transfer the video and put the hard drive back into the camcorder. Might sound crazy but its a very effective way considering the fact that it is quite easy to remove the hard disk from most camcorders.
Let me know if you need more help,
Sai.
Jan 03, 2010 | Panasonic SDR-H40 HDD Camcorder
FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Aug 21, 2009 | Canon ZR500 Mini DV Digital Camcorder
Canon HV10 not recognized
It appears that you are missing a driver from Canon for your camera. FireWire is an unusual interface and most PCs were not plug-and-play for this interface.
Sep 21, 2017 | Canon HV 10 HDV Digital Camcorder
Can't upload videos to computer
Hi, I am not sure why cameras dont come w/ firewire cord. May be its expensive..?
Neways, You need to use the 4 pin firewire to 4 pin firewire cable to connect PC to the camcorder.  http://www.bluejprojects.com/blog/articls/video-2-pc-gs120/firewire-ends.jpg
This camcorder model has the firewire port. Please check the manual carefully to find its location.
You need to switch on the camera. Keep it in play/ edit mode. Open movie maker. Its should detect the camera now. If not, try installing the software which came with the camcorder. It might have any drivers.
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Cant upload movies from my MINI DV CAMCORDER
Check if it has the firewire you are using looks like this
4 pin firewire:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Sep 23, 2008 | Canon XM2 Mini DV Digital Camcorder
Canon ZR800 won't connect
Your saying 4 pin USB firewire. Which one is it?
It should be 4 pin firewire.
What is the error message that you are getting?
Jun 09, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
538 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
