Question about Philips DVDR70 DVD Recorder
How to connect to sky
Just got unit with no instructions.how do i connect it so i can record off my sky?
    Master:
  • 601 Answers
Plug your recorder into the SCART connection labelled VCR and plug that into a SCART connector on your recorder.
To record from the Sky box, change the input channel to the SCART connector that the Sky box is plugged into and record away!
Posted on Dec 12, 2011
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Hello! I have just purchased a LG DRT389H DVD recorder as I want to copy the programmes that I hv on my sky+ box. I have followed every instruction in the book but for some reason am just unable to do so....
Connect the sky box to the dvd with a scart lead,plug it into av2 on the dvd.When you want to record from the sky,select av2 on the dvd as your record channel.Check that the scart is fully in on the tv and the sky for sound problem.
Nov 15, 2009 | Televison & Video
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Jun 01, 2009 | Televison & Video
Cant record sky
connect it to the box with a SCART lead, select A1 or A2 with the channel up / down buttons and away you go
(select A3 if you use the phono connectors under the front panel)
Mar 01, 2009 | Panasonic DMRES20D DVD Recorder
Panasonic TV Instruction Manual
Is there anything mentioned about cable accessible via the remote ... assuming you have one that works for the unit?
Apr 23, 2017 | Panasonic Home Theater System System
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Philips DVDR70 DVD Recorder Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
