Question about Frigidaire Refrigerators
I have a Frigidaire affinity washing machine AF7000FS1. The error code is E57. What is the problem and how should I fix it?
  • melakma May 03, 2010
    I checked the drum and indeed it does turn freely. Do I use the same procedure you have written down or is there an entirely different procedure if the drum does turn? Please mark down step by step like you did in the previous reply, it was very precise. Thank you very much!
    President:
  • 1,554 Answers
The error code E57 indicates a high current in the inverter either due to a motor problem or tub bearing problem. Open the washer door and turn the drum by hand to check if it is turning freely. If not, remove the rear panel and remove the drive belt. With the belt removed, turn the motor pulley and the drum pulley by hand to check where is the restriction coming from. Replace the drive motor if the rotor is stuck or stiff and check the tub bearings if the drum pulley cannot be turned freely. Measure the resistance of the motor windings if no restriction is found in the motor and the drum pulley. Using a volt-ohmmeter set to R X 1 scale, the resistance reading should be between 4 ohms and 6 ohms. Replace the motor if the readings are incorrect. The motor winding terminals are pins 1,2, and 3 on the motor terminals. Check the connections between the motor and the motor control board including the connections between the motor control board and the machine control board if the resistance readings on the motor windings are correct. Make sure the connections are good and snug fit. Clean the terminals and connectors and reseat them several times to help clean out the terminal leads and ensure a snug fit connection. Replace the wiring harnesses if necessary.
Posted on May 02, 2010
  • Jahn27
    Jahn27 May 03, 2010
    Just proceed with the procedure outlined previously. The verification of the drum is just the first step to make sure it is not stuck or restricted causing the high inrush of motor current that triggered the error.
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Frigidaire affinity error codes
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Mar 12, 2015 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Error code 57
Good Morning Aicia, regrettably, an error code E57 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your unit is experiencing. Thank you for allowing me to assist you.
Aug 05, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire E57
Hello Daniel Huntley - Typically error code E59 indicates that that washer is not detecting a tacho signal for about three seconds. Contact a professional to move forward accurately. Certified technicia will need to remove the belt from the motor, spin the motor pulley, diagnose the speed control board and etc.
Jan 07, 2013 | Frigidaire Affinity ATF8000FE
Error code DR comes up on my Frigidaire Affinity and won't keep running
It is telling you there is something wrong with the door lock assembly. You will probably have to replace it, but check it first for a broken wire or some other problem that you can fix.
Here is a link to the part if you need it.
Here is a link to a service manual for your machine that will take you through the testing and repair process.
http://www.emaservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
Oct 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Refrigerators Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
