Question about Acer Aspire One PC Notebook
I am looking at the mother board of an Acer aspire one notebook computer. I need to view a diagram of the cmos battery to remove it to resolve a password problem.
    Guru:
  • Acer Master
  • 1,705 Answers
The CMOS battery is usually located/accessed by removing the keyboard.
Acer don't seem to want to share that kind on data so here's some stuff which may help, but its for an ASPIRE 3000:-
Before you begin, back up your data and remove the battery. CMOS Bios will be lost but will reset on restart.
    Instructions
  1. Step 1 Open the laptop computer's screen and lay it back as far as it will go. Be careful not to stress the screen and cause any damage, but press it hard if needed.
  2. Step 2 Press a flathead screwdriver under the front of the plastic bar lining the back of the laptop's keyboard. Pry the bar up slightly and hold it with one hand.
  3. Step 3 Pry up the other side of the bar with the flathead screwdriver and fully pull out the bar. Keep its ribbon cord connected and set the bar on the laptop's screen.
  4. Step 4 Remove the two Phillips screws securing the computer's keyboard. Then, slide the keyboard up and out to remove it. Again, do not remove its ribbon cord, and set the keyboard over the laptop's touch pad.
  5. Step 5 Remove the four screws securing the cover plate over the motherboard and remove it as well.
  6. Step 6 Locate the CMOS battery at the bottom right corner of the motherboard.
  7. Step 7 Remove the battery by prying it up gently with the flathead screwdriver. Then, replace the battery with a new one of the exact same specifications.
  8. Step 8 Replace all the parts in the laptop in the reverse order that you removed them. -Battery Replacement
This didn't quite do the job, the Aspire was a bit of a so and so. So here's how I changed it on a 3000:-
Acer Aspire 3000 CMOS battery replacement.
Before going any further, you need to know that Acer have done you no favours, this laptop is especially designed to raise revenue for Acer and other laptop technicians. This is a fiddly task and you could do with 3 hands.
1) The cmos battery is on the motherboard about half way down the left hand side, turn your laptop upside down and you should see a locking screw for the optical drive, its just inboard from that screw under the bottom cover plate.
2) The motherboard on the ACER Aspire 3000 is upside down, so it faces the bottom plate or table it sits on.
3) The battery is a 3v Maxell ML1220 or equivalent. About the size of your little finger nail.
Before dismantling your laptop, disconnect the power supply and remove the battery. Then read these instructions thoroughly, make sure you are happy with what you are going to do.
1) Ensure you've got plenty of work space, a plate/dish for the screws and I like to work on a newspaper so I can swivel it all around without scratching anything.
2) Close the laptop, remove the screws from the 3 hinge covers.Open laptop until flat, gently prise off the top backplate. It includes the hinge covers, buttons etc and continues down as far as the top of the keyboard.
Start at one end gently teasing/prising it upwards until it comes free, there are no connections.
3) Removed the 2 screws holding the keyboard down, lift the keyboard gently and place it upside down on the mouseplate, don't break the ribbon connector.
4) Remove the three remaining screws from under the keyboard, one of these is a second optical drive lock screw. Replace the keyboard in its bed, close the laptop and turn it over.
5) Remove all screws and covers from the bottom plate. Remove HDD and the Optical drive, but leave CPU, RAM and WIFI in place. There are 2 further screws one in the battery well and one in the HDD well,remove those also.
6) Very gently, from the side of the laptop where the DVD drive sits, prise the bottom plate away. It won't come away completely. There's a speaker connector at the front at the other end. Bear in mind you'll probably need the lid open as well.
7) Once you have the bottom plate prised far enought apart, you should be able to see the battery, on the motherboard about half way down just about where the back of the DVD Drive would sit. Its in a white plastic mounting, and should be able to flick it out with your finger nail or a screw driver. It may be a good idea to get a second pair of hands to hold the laptop while you replace the battery.
Remember the negative side of the battery sits in the mounting, Positive side upwards.
8) Re-assemble laptop, reverse order to dismantling.
9) Keep fingers crossed whey you re-boot.
Good Luck.
Posted on May 02, 2010
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
Where is the CMOS battery on an acer aspire x1700 desk top computer
Most motherboards use a coin size 3 volt lithium battery type CR2032.
Ti help you.
Download the manual for your model computer from this WEB site.
http://www.manualowl.com/p/Acer%20Computers/Aspire-X1700/Manual/65650
Feb 03, 2013 | Acer Computers & Internet
Where is the battery on the mother board on a acer aspire 6920
LOL, it's there Louis, you just have to take the laptop apart to get to it in most cases. I assume you are talking about the CMOS Battery.
Apr 09, 2012 | Acer Aspire 6920 Notebook PC
Where is the cmos battery located on a acer aspire 5050
It is under a flap under the laptop A little round 3.6V cell.
Mar 23, 2010 | Acer Aspire 5050-3242 Notebook
How do I access BIOS if I don't know the Password?
If upon boot up and pressing DEL button asks a supervisor password, then you just need to take out the CMOS battery from your computer's mother board. Let it stay for like 3 minutes and return back the battery. This will remove the password in the bios. Good luck!
Oct 25, 2009 | Acer Aspire 1800 Notebook
My acer netbbook wont come on the power light is litt
Mother board or memory module can be the problem. First remove the cmos battery and switch on, if its ok then reinstall the cmos battery and see.check with other memory module or if you have 2 modules one at a time. If problem persists, try heating the motherboard display chipset with a blower, if you are a hardware technician. This should be done by only a professional as u can damage the motherboard and other parts. Last resort is replace mother board.
Sep 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Have an acer aspire 5315 laptop. I cannot reset the HDD password, so I can get on the computer
Remove the Acer BIOS passwords by simply opening their notebooks and removing the CMOS batteries for 30 minutes.
Once your BIOS password is removed, you will need to press the <F2> key during POST (Power On Self Test) to enter the Acer BIOS setup. See the below picture for reference
img-resized.png Reduced: 86% of original size [ 739 x 561 ] - Click to view full image 5672inside.jpg
May 19, 2009 | Acer Aspire 5520-5908 Notebook
Need to remove cmos battery
if you will remove the cmos battery it will reset all settings to the default ...or optimal defaults ...and indeed it will forget the password ...but for this you have to get to the mother board ...and to remove the battery for a moment manually ...you will recognize it cause it looks like a ag series battery ..( electronic watch battery ) but larger ...you can not miss it ...be careful and good luck ...after that you may reinstall and format it as you please..
Apr 06, 2009 | Acer Aspire 3000 Notebook
I need to replace the cmos battery on my acer aspire 5630,
if you remove cmos batt. then the default bios is loaded....you can find it on the mother board a round shape battery..
Jan 17, 2009 | Acer Aspire™ T180 PC Desktop
Clear bios password on acer aspire 5100-3959
short the battery hold a piece of wire on to the positive and the other on the negative for about 10 seconds this should short the battery it does no damage to any thing else.
Sep 16, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire One  PC Notebook Logo
406 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
