Question about Pride Mobility Products Pride Victory 10 - Three Wheel
Battery charger not working. A white wire that connects to the AC plug has become disconnected. Can soldering it back on work okay?
  • 46 Answers
Yes this is a common problem on a victory scooter i know i have one and the same problem just solder it up carefully
Posted on Jul 11, 2010
The circuit board where the battery plugs in not making a good connection and gps wont come, the wiring from car lighter to gps is good , canyou solder wiring to power circuit board.
Hi, yes it's possible you need a soldering iron and 60/40 rosin core solder, remember that soldering iron can make serious burns so be careful, and always work with the device disconnected from any power source.
Nov 13, 2015 | Magellan Car Charger Vehicle Power Adapter...
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
Amilio laptop not charging in spite of new charger
please measure the output for your charger,normally they have 19.5 vdc exactly, if they do not measure the adapter is faulty, repair or replace.If the output is o.k the battery can be faulty. Use the software diagnostic coming with the computer, restart the computer HOLD the key f2 or esc depending of your computer model, and make the diagnostic.try again and see what is the result, if the battery is o.k or faulty.God bless you
Apr 05, 2013 | Fujitsu Computers & Internet
I have an everex nc1500. it was on working fine, then it suddenly went dead like it was on battery,(but was on charger). now no lights come on ,it doesnt charge, doesnt try to turn on in any way. it acts...
This seems like a poor soldering job at the factory which has become loose/disconnected over time, affecting the power port the ac adapter plugs into. Take the laptop to the shop and have your power jack inspected.
Mar 10, 2011 | Everex StepNote NC1500 Notebook
Intermittent power supply, problems whit the jack, how I can change that? thanks, Ing. Elton Vargas
1) Check to make sure the problem isn't the cable going into the plug, from the AC adapter. (Charger)
A lot of times, where the wires meet the back of the plug, that goes into the laptop DC Power Jack, is bad.
The wires have a break from becoming stretched. Makes an intermittent contact.
Same thing for where the wires meet the charger body.
AC adapter plugged into power, unplugged from laptop, use a multimeter set to the DC voltage scale.
Use the alligator clip attachments for the probe leads, attach the probe lead's to the AC adapter's plug, and wiggle the wire, check for an intermittent break.
2) AC adapter (Charger) unplugged from laptop, Battery removed, see if you can wiggle the center pin of the jack.
You may find the entire DC Power Jack will move a little.
If the center pin does not move, but the entire body of the jack does, the jack may just need to be
resoldered to the motherboard. The solder connections may be cracked.
If the center pin moves, replace the jack.
To replace the DC Power Jack, or repair the solder connections,
1) Remove all power to the laptop. AC adapter and Battery.
2) Observe Anti-Static Precautions:
Buy and wear an ESD wrist strap. (Electro Static Discharge) Connect the alligator clip to a good ground source. I connect mine to the metal frame of an open, empty desktop computer case.
(You don't need an Anti-Static Mat)
The price of an ESD wrist strap is around $3 to $8. Found in a multitude of places.
Example,
http://www.costcentral.com/proddetail/Cables_Unlimited_Anti_Static_Wrist_Strap/ACC1400/10720671/froogle/
3) Completely disassemble the laptop down to the bare motherboard in your hand.
No Processor, Heatsink assembly, peripherals, nada.
TIPS:
A) You may wish to take photos, or make a video as you disassemble, for your first time. Also make notes.
After the first laptop the next one becomes easier.
(All of them follow a basic path when disassembling. Toshiba, HP, Acer, Gateway, you name it)
B) Use a multi-container for the various screws. Label each container for the area the screws came out of.
There may be 60 or more screws, and 12 different types of screws. Some look VERY similar to each other, but are NOT. DO NOT mix them up.
You can use a clean egg container in a pinch. Label each egg holder.
C) Take your time, use patience. Practice your soldering, de-soldering skills before working on the Toshiba's DC Power Jack, if you're rusty.
Use Desoldering Braid, and not a Desoldering Tool. (Solder S-ucker) The desoldering braid works MUCH better! (Also known as solder wick)
Pictorial, with details on how to disassemble the Toshiba Satellite A70, or A75 series of laptops,
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
You can click on each photo to enlarge.
Page 2, and 3 icons are at the bottom.
(You are on Page 1.
Page 1::Page 2::Page 3 )
One source for a Toshiba Satellite A75-S209 DC Power Jack,
http://www.laptopjacks.com/view_part/For-Toshiba-Satellite-A75-S209-DC-Power-Jack-TS51625.html
Toshiba Satellite A70 series Service Manual, (Free)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that begins with Satellite A10.
Scroll across to A70, and click on it.
This is a PDF file. May take up to 30 seconds before you see the first page.
May take additional time to fully download.
(Took me around 40 seconds before I saw the first page, with a medium speed DSL connection)
Regards,
joecoolvette
Oct 20, 2010 | Toshiba Satellite A75-S209 Notebook
2 months ago ive bought new charger...cause there was a fault with my previous one. It might also be a socket on laptop, so ive fixed both of it!but in the recent time,something went wrong...my charger...
Turn everything off. Take off the battery. Connect the ac adapter and turn on your computer. If it works with the ac adapter connected and your battery off then you have a defective battery.
If it does not work then it's either your ac adapter or your dc jack inside your computer. Try a different ac adapter at the store you bought the battery and you'll know if your adapter is bad. If it works with another adapter then exchange the adapter again (I know, I know, I've been there). If it does not work with another adapter then you're back to the dc jack but at least you'll know for sure.
Make sure that whoever is replacing the dc jack is good at soldering and replaces it not just solders the same one back on. Don't forget the shield to the dc jack. Good luck!
Oct 16, 2010 | Computers & Internet
Acer Aspire 5520 Power Problems! :(
1. Actually the problem is not with the charger / adapter!
2. The plug-in port / jack of the laptop has become loose.
3. Don't try to work out the charging by adjusting the adapter plug with different angles. It will just damage the plug-in port (the wire inside the port will become loose and unaligned)!
4. Contact the Acer authorised service center for repair / replacement of that plug-in port / jack in the laptop! It'll just cost some bucks!
please rate this advice if it helps....tc! :)
Jan 14, 2010 | Acer Aspire 5520-5156 Laptop
New charger but no ac power to pc
A common problem is for the power jack connections on the system board to go bad. They break loose from the main board because the power plug gets flexed and then the power doesn't get from the adapter to the board. No power light (or intermittent flickering) and no battery charging results.
What you need to do (or have done) is to resolder the power jack onto the board. This isn't difficult, but it involves getting the main board out to reach the solder side. In some cases the board can be damaged because of the bad connections and isn't repairable. Then the board needs to be replaced. But most often the soldering fixes the trouble.
Apr 08, 2009 | Dell Inspiron® 1501 (N11157) PC Notebook
Acer 5100 laptop doesn't work on ac or charger battery
Motherboard is bad and will have to be replaced unless of course the AC Jack on the back of the laptop is loose. That would cause the ac adapter not to charge and then you would have to take the motherboard out and put solder on each leg on the bottom of the ac jack to make sure it stays in place then the ac adapter can charge the battery properly.
Even going thru the solder method the motherboard could still be bad and have nothing to do with the ac jack.
Mar 08, 2009 | Acer Aspire 5100 Notebook
Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Jul 30, 2008 | Toshiba Satellite A105 Notebook
Pride Mobility Products Pride Victory 10 - Three Wheel Logo
142 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
