Question about Keurig Platinum B70 Coffee Maker
What is wrong with my Keuring Platinum B70 doesn't always dispense the water when it says it is brewing?
    Problem Solver:
  • 8 Answers
The unit inside may either be needing a descale even thought the display doesn't say it... or... in my case. the electrical connections go intermittent...
to fix... the black plastic cover needs to be removed and the electrical panel cover (located in the right lower side ) needs to be removed, and all connectors need to be reseated...
for more info re-ask another question... on how to remove the black outer cover... I answered one problem with this procedure.
Posted on May 02, 2010
Call Keurig. This is a defect with this model and they will replace it. Unfortunately your replacement may have the same problem. Keep after them to keep replacing it until you get one that works correctly. Good machines do exist! They're just hard to come by. I'm returning my second machine today and crossing my fingers that the third time will be the charm.
Posted on May 21, 2010
Descale
You need to purge the system. Clean the upper needle port with a paperclip end. Stick it all the way up the tube and into the reservoir. That will allow water and air to push out from the chamber. Make certain the Water Filter is changed. Blow out the tube from the lower water container with Canned Air. Always use Distilled or Filter water as city water has too many minetrals that collect inside of the heating chamber.
Mar 25, 2014 | Keurig Platinum B70 Coffee Maker
Keuring says "ready to brew" but won't!
Clogged exit port from heater section. Clean as per manual page 18.
Aug 16, 2012 | Keurig Platinum B70 Coffee Maker
My coffee maker states that it is brewing but it doesn t take any water out of the reservoir nor dispense any coffee
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 19, 2011 | Keurig Platinum B70 Coffee Maker
Platinum B70 "brew temp set"
Brian, sorry, (re post ) with complete question? and make and model
May 11, 2011 | Keurig Platinum B70 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Mar 22, 2009 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
1,288 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
