Question about Food Processors
The screw on cap that fits on the bottom of the container is broken
Yes
Posted on May 02, 2010
What tool is needed to undo the four screws below the Magimix. I need to remove and clean the buttons which won't depress and sticky due to an overflow of mixture. Thank you
you did not described the screw or model of your machine, most of them use "secure" screw system of various shape, you need to check what shape is your particular screw and then go to closest hardware store and buy set containing that particular screw,
magimix use mostly torx screws, but you need to check as this vary from country to country... just to make our life more difficult...
Feb 08, 2015 | Magimix Food Processors
Motor base cover for dlc 7 super pro
Try buying a new motor base on eBay. It's actually quite cheap. If you are daunted by the shipping cost of this monster, you can always ask the seller to sell you just the brown bottom cover. Under each foot is a screw which attaches the molded base it to the rest of the assembly. It's a lot cheaper to just have that part sent to you. This works as long as you are handy in making the switch of the base.
May 27, 2014 | Cuisinart DLC-7SFP Pro Food Processor
The smaller jug blade is not revolving
Check the nut fitted in the blade.If it is loosely connected then fit it with screw driver correctly.
Jan 05, 2011 | Braun K 750 CombiMax Food Processor
Blender bottom stuck
I tried the vinegar thing but it didn't quite work. We blended some smoothies with yogurt and it leaked through the bottom. No big deal, we tightened it up. We didn't clean it immediately. By the time we went to clean it, it was stuck. The vinegar didn't work, tried baking soda with vinegar, didn't work. Finally we ran the bottom underneath hot water for about 5-10 minutes. Finally after one strong turn the bottom came off. We have an oyster, the base can be used as well to take the bottom off but it turns counter-clockwise.
Feb 26, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Stops working due to short
The original posting contained the solution.
Dec 05, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Can't figure out how to turn on Regal LaMachine I food processor
It's very easy--but you have to know the trick--I know 'cause it took me awhile to figure it out. Place the machine with the on-off/pulse button on your left. Lock the container in place--the handle will be on your right. Put the blade on the shaft. This is the trick: Lock the lid in place so that the shoot is directly in front of you and the "***" slides into the **** on the left of the machine (between the container and the inside of the machine, left of the on-off button). Good luck!
Nov 25, 2008 | Regal Ware K813BK La Machine Food...
Robot coupe r 301 ultra
Remove the base the screws are under the rubber feet,on top of the machine there are three screw caps remove these with a bradel, unscrew screws with large torx screw driver, remove spindle anti clockwise by locking out fan at base. for all Robot coupe parts go to http://www.catering-machines.com/
Jun 06, 2008 | Food Processors
Food processor attachment won't fit the machine
I actually got tired of trying to figure it out and just unscrewed the bottom and removed the plastic part. It works fine now!
I had a screwdriver to use with a mobile phone, I think its called t9 or something.
Jan 10, 2008 | Bosch MUZ4MM3 Food Processor
Repair of braun K 750 Combimax
ON LINE IS NOT POSIBLE, GO TO YOUR LOCAL REPAIR SHOP & ASK FOR SIMILIER CONTAINER
Mar 20, 2007 | Braun K 750 CombiMax Food Processor
Food Processors Logo
14 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
