Question about Roper REX4634KQ Electric Dryer
No Heat Dryer cycles work, but there is no heat. Should I replace the fuses first before anything else? where are they located?
  • Roper Master
  • 43,501 Answers
If you have a gas dryerNo Heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 03, 2010
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
MY HOTPOINT AQUARIUS TCM580 CONDENSER DRYER STOPS WORKING AFTER ABOUT FIVE MINUTES USAGE AND IN SO DOING TRIPS OUT THE MAIN HOUSE FUSE, WHAT CAN CAUSE THIS PROBLEM
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 05, 2014 | Hotpoint Dryers
LEC6646
follow this steps and fix it. Merry Christmas
. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Dec 18, 2013 | Whirlpool Dryers
My whirlpool dryer LER4634PQ0Runs but doesnt heat up?
It could be a number of things, but i would start with these first:
THERMAL FUSE.
The thermal fuse is designed to prevent the dryer from overheating. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
There are also a couple of 'thermostats' that could be the problem:
The 'high limit thermostat' is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
OR:
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
I hope this helps you fix the problem.
Dec 02, 2013 | Whirlpool LER4634PQ Electric Dryer
Dryer works, no heat. Checked power to dryer. Both fuses are supplying electric to dryer. Replaced heating element, replaced thermostat, replaced thermal fuse. All replacement parts are new. I did...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Dryers
I have a maytag gas dryer model no# ldg7314aae.The dryer runs but there is no heat. the dryer vent was cleaned as well as the interior of lint and still no heat.I was wondering where to start as far as...
your thermal fuse near the dryer vent opening or blower housing inside the unit,this is a one-shot fuse when it burns out you can't reset it,you need to replace it,then the radiant sensor(senses the flame),high-limit and cycling thermostats located on the burner tube on the dryer,then the boost and secondary gas valve coils located on the units gas valve body near the gas inlet to the burner tube
Apr 27, 2010 | Dryers
No heat is produced on any cycle
Check the fuse located in the back of the dryer. First unplug the dryer. Then take the back panel off. Now look for a white or tan piece with two wires going to it. It's about 3/8" wide and 1 1/2" long. This is your fuse. If you have no way to test it. You can connect the two wires going to it together, tape them so that they will not tuch anything and short out. Turn the dryer on and see if it heats. If it does, dont leave it like that. It a fuse. A safety devise. Replace it before you dry a load.
Aug 15, 2009 | Whirlpool Washing Machines
Dryer won't shut off at end of cycle
First of all if you want heat it's probably a burnt up thermal fuse due to lack of air to the dryer. But if the timer is getting stuck you'll just have to replace the timer. Theres no way of fixing the timer just replace it and then replace the thermal fuse (it's located on the back of the dryer) and you should be up and running also have the ducting cleaned out.
Please remember to unplug the dryer before working on it.
Hope this helps
Jason
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Roper REX4634KQ Electric Dryer Logo
61 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
