Question about Bissell CleanView 3596 Bagless Upright Vacuum
High pitched screeching/broken handle release
My Cleanview Revolution Deluxe (3596) makes a high pitched screeching sound while vacuuming; however, the suction is still great on this machine. Also, the handle doesn't stay up (whatever needs to be released to unlock the handle). I know I should probably just replace it but even with the noise and handle problem, it still works fantastic. Is there anything I can do to fix it; and where can I get the parts? Thanks much.
    President:
  • 1,673 Answers
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Posted on Mar 30, 2008
Need a new belt for a bissell lift off revolution turbo
Hi Dale, sorry to hear the belt has broken. Now is a good time to order filters for orders that are $30 or more receive free shipping. Here's a quick link to ordering one.
http://www.bissell.com/parts/?sc=search2&searchtext=3760
Jan 26, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Can you still by the bissell 3596 Clearview revolution vacuumn? Was trying to buy online but keep finding it unavailable
Unfortunately, it doesn't look like it's still for sale. Bissell no longer offers it for purchase online.
If you go to the Bissell web page for the Revolution, you can type in your zip code and find out if any stores in your area sell it.
Nov 26, 2010 | Bissell CleanView 3596 Bagless Upright...
Bissell 35962 Cleanview Bagless Revolution Upright Vacuum hose is clogged with sock where hose meets handle attachment. Attempted to use broom handle to push back through suction opening. Sock is...
If you have access to a small sink "snake" used to clear clogs in sinks, you might be able to use it to "snag" the sock and pull it out. Needs to be a metal sewer snake so that you can tug on it if and when it snags the sock.
Sep 05, 2010 | Bissell 35962 Cleanview Bagless Revolution...
I changed the belt on my bissell Cleanview revolution 3596 twice and both times the belt burned and starting to smoke. I'm not sure what to do now I have two broken belts what could I be doing wrong?
Sounds like the brush that the belt runs (or is supposed to run) is being kept from turning. If you can get the brush out to clean it and lubricate the ends that go into the holder clips, this should solve the problem. With the new belts burning and smoking it appears that the motor is running okay, but as I said, the brush that is supposed to be turning is frozen solid from debris or dirt. Need to free the brush and lubricate the brush holders with some WD40.
Sep 05, 2010 | Bissell CleanView 3596 Bagless Upright...
I need a manual for the Bissell 3596-1 upright vacuum
Hi, go to bissell.com and put in your model number 3596 in the search box. Within the first result will be the user guide. Hope this helps.
May 29, 2010 | Bissell CleanView 3596 Bagless Upright...
New Bissell Cleanview Helix is aking a high
It most likely is a worn drive belt. Here is a link to the belt you need and the manual:
Bissell Cleanview Helix Belt and Manual
Nov 24, 2009 | Vacuums
Screeching motor on a bissell 3595
Your motor is must likely bad and you would look at around $60 to $70 for a new one.
Nov 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
My vacuum get cloged
check the bottom under roller look in hole run hanger in it a little ways if u pull n e thing out it might be clogged there
Dec 03, 2007 | Bissell CleanView 3596 Bagless Upright...
Bissell CleanView 3596 Bagless Upright Vacuum Logo
486 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
