Question about Stoves 720EF Electric Double Oven
Stoves 058568000, grill element meggers out OK but no power supply coming through ! Is there a hidden TOC somewhere . I'm a registered electrician but don't want to have to strip the whole casing off this free-standing electric range if there is an easy way to fix fault.
  • 250 Answers
Not too sure of the model, but on the 720 the grill will not operate unless the door is down (microswitch control - you can hear it operate when the door is shut/opened) and the overheat device has not operated.(Cooling fan has to be running)
Posted on May 08, 2010
Oven. Tripped on switch board when baking
This sounds like the grill element has blown, usually when an element blows it will take out the circuit breakker or RCD at the consumer unit.
If you check around the grill element you will probably find a very small hole in the side of the element, this doesn't happen every time but most.
These are usually quite easy to change but remember to turn off the power before doing anything on the cooker.
You should be able to order the part off the internet, lots of companies supply these parts. You will need your model number and obviously your credit card.
If you don't feel confident, I am sure a local electrician will help you. I would advise that you don't use a company that specialises in appliance repairs as they will charge you a fee just to come out to see you.
Hope this helps
Jul 18, 2015 | Ovens
The grill gets hot but doesn't brown the food?
Normally, if a grill element fails, it just stops working. So if they are working then on full power, both elements should get red hot! If this is the case, all I suggest is that you try experimenting with different heights with the grill tray. And by the way, don't shut the door when you are grilling as this shuts the grill off!
Oct 28, 2011 | Stoves 720EF Electric Double Oven
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Electric grill is intermittant or cuts out after 5/10 minutes
There are two overheat devices in the oven. One feeds the oven timer/programmer for the main oven and the other feeds the grill. If the cooling fan is running ok, then I would suspect it is the cutout feeding the grill elements that has perhaps with age is not working as it should do.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
No Grill operation for stoves 720ef
Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
With your fault, can you here the switch operating, if not it just may be stuck?
Dec 12, 2009 | Stoves 720EF Electric Double Oven
Smoke comes out of grill on electric cooker
This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
Nov 10, 2009 | Stoves 720EF Electric Double Oven
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Feb 24, 2008 | Ovens
Stoves 720EF Electric Double Oven Logo
177 people viewed this question
Top Stoves Ovens Experts
ashburton
John Tripp
John Tripp
Are you a Stoves Oven Expert? Answer questions, earn points and help others
