Question about Sony Playstation 3 (PS3) Console
Hard drive corrupt
My ps3 says the hard drive is corrupted press x to restart. What can I do to fix it and will I lose my data?
    Novelist:
    Champion:
  • Sony Expert
  • 207 Answers
You can try reformatting your hard drive...on your xmb go to settings>system settings>format utility
just know if u do this you'll lose all and everything on your hard drive.
if that doesn't work you can replace your hard drive. if you look on the left side of your ps3 you see a tab that reads "remove this tab to replace your hard drive"
if your looking at it there is a small groove on the right side where you can use a small screw driver to lift it open.
once thats done you'll be looking at the hard drive. notice the small screw holding it in place. *CAREFUL YOU DO NOT WANT TO STRIP THE HEAD OF THE SCREW* use the right size screwdriver and note that the screw is on very tight. so using the correct screw driver push in with little force as you begin to loosen the screw.
once the screw is off you should be able to lift the metal tab and be able to slide the hard drive to the right. once thats done just pull it out of your ps3 using the same tab
now put in the new hard drive into your ps3 as far as it'll go and slide it to the left to connect the hard drive to the ps3. you won't see it but you'll feel it sliding into place.
once thats snuggly in place screw on the screw being careful not to strip the head and making sure its on tight. and finally replace the plastic tab to cover the hard drive.
once all of that is done you'll have to reformat the new hard drive for your ps3 to recognize it.
Posted on May 02, 2010
Code 80010514
the solution
Ok so I've fixed my issue. I will run through what you will need to do to fix yours if you are having issues with the blu-ray drive and general PS3 system operations like the XMediaBar this is totally worth a shot ... I doubt this will fix any other issue. If not then your blu-ray drive/ PS3 is probably dead and needs replacement via the method listed above or by sony.
If you can, I suggest you back up your PS3 first. The menu that you will access to can fully erase your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don't make a mistake!! Sorry, I had to say it, I don't want anyone mad at me if they make a mistake, don't back up their data and erase it, and then blame me...
The current version of the ps3 firmware has a "recovery console".
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like "you have Corrupted System Data. Your PS will now replace this data" Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that's stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive.
However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren't corrupted) back to the flash memory which is corrupted thus fixing the problem
Jan 13, 2011 | Sony Playstation 3 (PS3) Console
Hi all, I can't "sign in" in PSN, it says you you
You seem to have some corrupted data on the hard drive regarding downloads and firmware. No fear this is an easy fix. First off...shut off ps3 so that its in standby. (Red Light On).
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that's stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system. Hope this helps...it did for me.
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Disc not being recognized.
The current version of the ps3 firmware has a “recovery console”.
You access it by
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem.
Aug 21, 2010 | Sony Video Game Consoles & Games
File system corrupt? wtf is that
Be sure to folleow these instructions to the letter, you could damage your PS32_bing.gif if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
You access it by
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory, which is corrupt, thus solving the problem.
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 says cannot start. the correct hard disk
You access it by
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
The hard disk's file system is corrupted and will
You access it by
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
Corrupt HDD
try formating in another ps3. you will lose all data but it will solve hard drive issue
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
Hard drive corrupted
remove hard drive and insert into diffrent ps3. Then defrag. you will lose all of your saved data but it will fix your issue.
Jun 01, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it comes up ''hard disc drive is corrupt''
My PS3 has done this before. If it is like mine then all you have to do is wipe all the memory and restart the system which should be one of the options it can give you if you click past the "Hard drive disc is corrupt screen." This can happen because you might of shut down the system by accident when it was saving a game thus the hard drive becomes corrupted. You won't lose any online info but you will lose memory to saved games and thing else that is saved on the HDD like Demo Games. I hope this helps you. If not then I am very sorry and I am sure it will be fixed if not by my advice.
Mar 09, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
