Question about Gateway 7326GZ PC Notebook
Gateway 7326gz multifunction button panel removal.Power button will light when I first plug in power supply but then extinguishes,ac light on laptop is lit as is the led on power supply.Possibly a button problem because person I purchased it from tells me when it starts it works just fine.Looking for a repair manual,used to have one but must have deleted it so not quite sure how to remove multi function panel without breaking it.Thanks.
gink0
  • 35 Answers
SOURCE: Power button on laptop is broken.
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
1s8
Posted on Jan 06, 2009
SOURCE: Unable to turn on my labtop (gateway 7326GZ) computer.
I saw this part available really cheap from Computer Parts Outlet.com
Posted on Jan 27, 2009
  • 27 Answers
SOURCE: Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Posted on Feb 17, 2009
  • 31 Answers
SOURCE: Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Posted on Jun 02, 2009
  • 5 Answers
SOURCE: Laptop does not power up or turn on anymore!
You seem to be in deep trouble..
It sure seems to be a motherboard issue. I will advise you to buy a new MBD. And to your relief, the data on harddrives will be "nil" affected by the motherboard change.
There might be an easier and cheap solution to the problem, but the area to be audited to find the solution is large with no guarentee that we will find a viable solution. Motherboard replacement will be an instant solution..
If you own a dell laptop, but a complete cover warranty that will include a free motherboard replacement and warranty for 1 more year..
Posted on Jul 01, 2009
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
My gateway ml6732 laptop will not power up...no lights come on when plugged into the power. Could there be a problem with the on/off switch?
Unlikely as even with the power switch off the power led would show current from the AC adaptor was reaching the laptop. Try testing the AC adaptor first by plugging a volt meter into the DC jack, with one probe set to the inside of the jack and the other to the outside, set at 20 volts and see if you get a reading.
If the power is reaching the DC jack, then check the connection at the jack port for tightness and make sure the jack is a good fit
Try removing the battrey and using it on AC power alone, sometimes a failing battery will cause problems
If this fails, it is possible that the internal fuse on the motherboard has gone
Dec 30, 2010 | Gateway ML6732 Notebook
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
The real button is under the button you see. You might be able to get the keyboard cover off. If it's not broken broken you could try to reseat it. The part unless you find a cheaper source is 149.00 (which frankly is ridiculous)
Dec 31, 2008 | Gateway 7320GZ Notebook
Gateway MT6451 Does not turn on
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
Gateway 4530gz notebook
I'm sorry to say ,but I think it's with the motherboaed. Use the AC plug with the battery removed ,and see if it will power up. If not, I think it's a bad motherboard.
Aug 04, 2008 | Gateway 4530GZ Notebook
POWER BUTTON BROKE, CAN'T START MY NOTEBOOK COMPUTER GATEWAY 7326GZ.
Did the power button come off or did it stop working. Broke has a lot of meanings.
May 29, 2008 | Gateway Computers & Internet
Will not power up
Do you have any stattus light or even the light like power on light on your laptop ??
Apr 29, 2008 | Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB...
Gateway 7326GZ PC Notebook Logo
179 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
