Please confirm that the head cleanings were done using the most effective method
listed below.
1. Make sure the printer
is turned on but not printing.
NOTE: You
cannot clean the print head if the any of the cartridges are expended. Replace
the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For
Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS
PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS,
then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right
click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the
drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS.
Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then
PRINTERS. Note: these steps may vary depending on how Vista is setup. Right
click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the
4.
Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to
clean the print head. Cleaning takes about 30 seconds, during which time the
printer makes some noise and the power light flashes. Never turn off the printer
while the power light is flashing, unless the printer has not moved or made
noise for more than 5 minutes.
6. When
the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click
NEXT.
7. If the nozzle check pattern has
no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to
clean the printhead again.
8. If the
situation continues after three cleaning cycles and nozzle checks, replace one
of the affected ink cartridge(s).
9. Once
the cartridge(s) has been replaced, please follow steps one through seven up to
three times.
If the nozzle check still
has gaps after you have run at least 3 consecutive cleaning cycles and replaced
the affected ink cartridge(s), your printer will require service.
Use the Printer Driver Utility to clean the print head. Alternatively, try this
SSC Service Utility.
Also try changing the affected ink cartridge.
All else fails, your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link
http://www.epson.com/loyalty .
Thank you but I tried this allready ,I cleaned the head till the cartridges lost 30-40% of their ink and nothing.Must be something else Thanks
I did this already but still nothing. How can I clean all the ink residue from the head cleaning
