Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
Harmony remote control - volume won't stop increasing when the button is pushed
    Scholar:
  • 41 Answers
First I would check if the remote is momentarily sending out the volume command or is it sending it out continuously. You can use this trick with any IR remote. Using a digital camera with display, point the remote at the camera and press the volume button on the remote. If the IR led is working then you should see it glow on the cameras screen. When you release the volume up button, the IR led should stop glowing. If it does not stop then you may have a sticky key or a problem with the program. If it shuts off then the Harmony is functioning ok and there is a problem with your receiver. Another way to test this is to press the volume up button and then immediately cover the remote with a blanket or take it to another room or remove the batteries. Let me know if the remote is continuously sending out the Volume command or is it momentary.
Hope this helps.
Posted on May 18, 2010
The volume control works to decrease volume but is very difficult when trying to increase volume
This may be an issue with the button itself getting caught on the plastic bezel of the remote. Sometimes this happens when the remote is dropped or the plastic bezel is nicked.
My recommendation is to reprogram the device you are trying to control the volume of. This issue may occur when the incorrect IR code is programmed into the remote. Some IR codes may work intermittently and as rolling codes. Check the program and respond if problems persist.
Jul 27, 2011 | Logitech Harmony 890 LCD Remote Control
The volume control will no longer increase volume
this is common, It may well work for most functions then let you down an one like volume! You should have at least three (but it should be more like 6) different codes to try and one should work. If your remote has a learning function and you have an original remote to hand, some have the ability to learn the function by direct lt beaming the remote command into the harmony itself.
Jun 15, 2010 | Logitech Harmony 880 LCD Remote Control
While watching TV the volume will suddenly mute.
Hi. Were you able to get this remote working again? I am going to suggest you try a firmware update, since you didnt mention that you had tried that. I find that usually solves weird problems like this one. You can do that by going through the following steps:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help.
Dec 29, 2009 | Logitech Harmony One LCD Touchscreen...
My volume won't increase on my LCD tv. What can I
I can help you reprogram your Logitech Harmony 520 remote for your LCD TV.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Oct 25, 2009 | Logitech Harmony 520 LCD Remote Control
The volume up button is not working. All buttons are working fine. It is just the volume up button that has stopped working.
If you can manage to open it, just clean the rubber pad, slightly rub with cotton moisten with alcohol
Aug 17, 2009 | Logitech Harmony 880 LCD Remote Control
Sometimes volume won't stop going up when I press +/- control
try programmin the ir code with a delay. .3 .4 usually will solve your issue. part of trouble shooting when the remote is connected to the server theres an option to increase or delay the ir emitter. hope this helps
Jun 04, 2009 | Logitech Harmony 520 LCD Remote Control
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
193 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
