Question about Video Game Consoles & Games
Foriegn games and available software
I purchased a game for the paystation 2 but the game is a german version wich is the pal version for german playstion software how can i get a playstation 2 format disc so I can play the game on my console
  • 55 Answers
You would have to buy an NTSC copy or mod your PS2.
http://www.videohelp.com/dvdhacks/sony-playstation-2/445
Posted on Mar 25, 2008
SOURCE:
Well i bought a game called 2k8 basketball here in philippines, but i bought my xbox on australia, then i tryed my game and it said, ( The disc's region code is incorrect for this consol ) so how can i...
Sorry you can't fix it. Most games are Region specific meaning that they are playable only on Xbox 360 systems from the specific region that you have. If you bought your Xbox 360 in Australia then it is likely PAL system and can only play Pal games.
"Determine whether the game disc is from the same region as the region where you purchased the Xbox console. To determine the region, view the back of the game package. Look for one of the following codes:
* NTSC: North America and South America (United States, Canada, Mexico, Chile, and Brazil)
* NTSC-J: Asia (Hong Kong, Japan, Korea, Singapore, and Taiwan)
* PAL: Europe, South Africa, India, Australia, and New Zealand"
If the game you have doesn't match with your Xbox 360 Region then you won't be able to play it. (but a few games are playable on multiple regions, check list below)
Check out this site prior to buying games to help identify which games that aren't PAL might be still playable on your system.: http://www.play-asia.com/paOS-00-3-xbox360_compatibility_guide-49-en-84-t.html
Notice that NBA 2K8 US version is not compatible with PAL system. If you had bought the US version of NBA 2K9 then it would have worked.
Aug 06, 2011 | Video Game Consoles & Games
I bought Rock Band drum set from Malaysia. But there was no disc inside the pack. I was trying to connect the same to my PS2 but asking for a rock band disc. Where can i purchase the same or can i get a...
As you've noted, you'll need to buy a Rock Band disc. You might be able to find one in the used game section of your local video game retailer (Gamestop for example).
Alternatively, you can purchase it online. Here is a link to the PAL version of the game. I linked to the PAL version (on amazon.co.uk) as you mentioned Malaysia in your question, which is a PAL region, and the UK is also a PAL region. The PS2 is region locked so your games must match the same region as your PS2.
Mar 21, 2011 | Video Game Consoles & Games
Cant play NTSC games
If you can't play NTSC games then that means your xbox is probably a PAL version. There's not really much you can do about this except to buy PAL version games :(
BTW, NTSC and PAL refer to different regions. NTSC Is north america, while PAL is usually europe.
Aug 03, 2010 | Microsoft Xbox 360 Console
How do i get a cd to work
What do you mean? Is it an audio file or a game? if its a game check if your PS2 version if its NTSC or PAL version on its main menu.
Check the cd for NTSC or PAL. PAL works with PAL and vice versa.
Jun 10, 2010 | Sony PlayStation 2 Slimline Console
How to play ps2 games on ps3
Ok well here is the "Skinny" 1). 20GB has no chrome trim, no memory card reader and no wi-fi. Not manufactured anymore. Has the best backwards compatibility with PS2 games due to Emotion Engine (PS2's CPU) and Graphics Synthesizer (PS2's GPU) installed.
2). NTSC 60GB has the same backwards compatibility as 20GB version, also has memory card reader and wi-fi. Has a chrome trim.
3). 80GB - extended memory, but reduced backwards compatibility with PS2 games, it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played. Available only in NTSC regions.
4). 40GB - can't play PS2 games at all (all PS2 chips were removed), has 2 USBs instead of 4, no memory card reader, has wi-fi. Avalable in black and white colors. White is on sale only in Japan. Uses 65nm technology (lower power consumption). Improved cooling system. It's the latest version. 40GB doesn't support SACD.
5). PAL 60GB - reduced backwards compatibility with PS2 games. it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played.
Wi-fi included in all models, except 20GB.
Feb 05, 2010 | Sony PlayStation® 3 (80GB) Console
Will a swiss or german ps3 game work on a US ps3 platform
No European games are in PAL format. US is NTSC. Sorry. Hope this helps.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Need HELP about the psp update version.
hi, firstly you will have to upgrade the version to play the game and secondly a upgrade is always a good idea, it will speed up, your psp and fix any bugs in the previous firmware and you will be able to play any games you have.
May 20, 2009 | Sony PSP (Piano Black)
Console set for English but Game Play is in German
Is it possible that the cartridge is entirely German? Was it an import? or did you purchase it at a local department store? or even, is it one of those 10 in 1 cartridges.
Dec 27, 2008 | Nintendo DS Lite - Onyx
Some gmes won't play.
Ok. Do you have a NTSC system?
Some PAL games will only run on standard and some will only run in HD and some will run on both if the PS3 is NTSC. The PAL games output at (576i/p) while the NTSC outputs at (480i/p). So honestly, I think that is your problem. You have a NTSC system and PAL games. If you do not have a HDTV then you will need to exchange those games for the NTSC version. Sorry for the bad news. It's not Sony's fault, it's how the game developers coded the games.
I hope this helps. Good luck to you.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Nintendo wii consule (european german version)
The Wii Sports manual can be downloaded here
The manual for the Wii console itself can be obtained here
As for changing the language in Wii Sports, I am not sure, but it usually gives you the option when the game first starts up, otherwise it might use the system language.
Thanks.
Nov 15, 2007 | Nintendo Wii Console
Open Questions:
Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
Oct 19, 2019 | The Video Game Consoles & Games
Video Game Consoles & Games Logo
57 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
