Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite error code f21
I saw posts about fixing the clogged drain with a mini vac...how do you do that step by step...please help.
  • 15,935 Answers
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
What does extreme cold have to do with f21 error message on kenmore elite front loader?
the pump could be froze,f21 is a drain problem,pump is either bad or clogged,remove the clean out in the pump,use a shop vac to do this,you can remove the drain hose get it down as close to the ground as you can stick the vac to the hose and suck out the water,or there's a black tube next to the clean out you can drain the water out of there or,if the door is open vac out all the water in the tub,then loosen the clean out and when water starts to come out vac it up until empty and check inside the pump to see if anything is in there.
Jan 03, 2018 | Kenmore Washing Machines
Tip
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
on Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
F21 Error Code
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
on Dec 09, 2009 | Washing Machines
I keep getting error code F21 on my kenmore elite which is a drain error the drain is not clogged and the drain hose is not clogged any ideas on what I could do?
The error code F21 is similar to F02 which both pertains to a draining problem. The usual cause is a blocked drain filter or a clogged/kinked. But since those areas are found to be not the source of the problem, the problem must be somewhere else. It is either the drain pump is broken particularly the impeller if the pump just hums/whirs or the pressure switch contacts are stuck/welded together and is, therefore, not tripping. The link below provides the detailed troubleshooting instructions the problem of this kind after the drain filter has been cleaned out.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers (Filter Cleaned)
Aug 21, 2011 | Kenmore Washing Machines
Getting F21 and F32 Codes Please advise
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer flashes f21 and will not finish cycle
Jul 22, 2010 | Kenmore Elite 45986 Front Load Washer
How to fix F21 error code on a Kenmore Smart Wash quiet pak4?
Dec 31, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite keeps flashing LD after I start to wash. Then the machine stops washing. Clothes are not wet, but I heard water going into the machine. How can i fix this?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Jul 27, 2009 | Kenmore Washing Machines
My Kenmore Elite HE3t is giving me the error masage F21. What can I do to fix it
Jun 16, 2009 | Kenmore Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
181 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
