Question about LG WM-2277HW Front Load Washer
"OE" message Just washed a rug and got an "OE" message during the rinse cycle. I took the rug out and ran an empty cycle clean out the washer, and got the same message again. The machine is locked and I don't know what to do. Thanks. jac
    Problem Solver:
  • 6 Answers
OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
Hopefully this fixes it!
Posted on May 02, 2010
    Problem Solver:
  • 8 Answers
This error code appears when the washer has not fully drained after 10 minutes.
The possible causes for this problem are: Oversudsing and Not Draining.
1 Do not use too much detergent. Highly concentrated detergents (HE2x and higher), require less detergent than regular detergent or non-concentrated HE detergent.
2 Check for correct drain hose routing. Make sure drain hose is not kinked or too far down the drain / stand pipe (average 6-8 inches).
3 Check for correct drain hose routing. Make sure drain hose is not kinked or too far down the drain / stand pipe (average 6-8 inches).
Steps to clean the drain pump in front load washers:
1 . Locate the access door / panel at the bottom front of the washer (If equipped).
2 . Gently, open the door or remove the panel.
3 Locate the drain hose and plug, if equipped. While using a drain pan or bucket to catch the water, remove the plug and allow the water to drain from the washer.
3(a) If the hose seems plugged and will not drain, it is most likely pulled out too far. Do NOT pull the hose until it is tight, leave some slack!
3(b) If the drain pan gets near full, plug the hose, empty the drain pan, then continue draining until all water is out of the washer.
3(c) Make sure the drain plug inserted back into the hose, it must be inserted fully.
3 (d) If not equiped with a drain hose, make sure drain pan or bucket is under the filter housing area when removing the filter.
4 Once all water is removed from the washer, the pump filter can be unscrewed by turning counter clockwise (typically 3 full turns), then pulled out of the filter housing.
5 Once removed, wash out the drain pump filter under running water at the kitchen or utility sink. Some light scrubbing may be needed to remove all soils from the filter.
6 Make sure not to damage or lose the O-ring gasket on the filter.
7 Before reinstalling the filter, check the filter housing for foreign objects and soils that could block the filter. Once foreign objects and soils are removed, then reinstall the filter, plug and door in reverse order.
8 Make sure the filter is fully seated and snug or it could leak. Do not over tighten, filter or housing damage could occur.
9 Run the washer and check for leaks.
Posted on May 28, 2010
Wa52j8700a dirt remains bottom of washer
I would try to run an empty washer through about 4 or 5 rinse cycles and see it the machine will clean itself.
I would also carefully wipe it out after each complete cycle.
God bless your efforts.
Feb 29, 2016 | Washing Machines
Washer fills with water during spin cycle
Go to repairclinic.com and have model number ready. They have videos how to check it
Mar 02, 2015 | Samsung WA422PRHDWR 4.2 cu. ft Large...
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
Was washing my kitchen rug and on the rinse and spin cycle I got an error message, perhaps because the rug was too heavy when wet to spin. I took rug out, water standing in washer, tried to clear error and...
With the Door Lock display on (which is what the red key indicates), are you able to open and close the door?
If so, you probably have a defective door lock assembly. Try unplugging your machine for a couple of minutes and plug it back in to see if it resets itself.
Oct 10, 2009 | LG WM-2277HW Front Load Washer
Code OE water is not being drained out
You may have a broken or plugged drain pump and needs to be diagnosed by a qualified LG technician.
Jun 26, 2008 | LG WM2277H Stainless Steel Front Load...
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
LG WM-2277HW Front Load Washer Logo
678 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
