Question about Pride Mobility Products Casual CL20KD Lift Chair Chestnut
Electronic Control Box Module on Triton PL3-01 not working
Where can I get the electronic control box/module for TRITON PL3-01
Electric Mobility Scooter repaired or replaced? Preferably in Ontario/Canada. Cost & time estimate, including shipping from near Barrie, Ontario.
  • John Cassels Mar 22, 2012
    I have the same problem! It looks like three transistors burned out. I called Monsterparts but they said their data for the gogo scooter (Pride) controller board does not mention it will work in a triton pl3-01 scooter. This part on their site looks identical, is it? Anyone know if Pride simply took over the triton scooter parts?
  • 3 Answers
I have a pl3-01 scooter in for repairs and 3 resistors on the circuit are fried and I can't get the color coding of the resistors to replace them. Can you send me a picture of your circuit board and I will see if I can fix this 1, and if I can, maybe I can help you out.
Posted on Aug 09, 2010
I have 6 OEM Triton circuit boards in stock from before they went out of business. I can be reached at tolhursts@hotmail.com if you need more info.
Posted on Sep 10, 2012
  • tillyhurst Sep 10, 2012
  • 3 Answers
Triton parts are very scarce since they are out of business.
Try LK Technologies, they are currently working on a repair kit for the PL03
Contact koornneefleo@yahoo.com for info.
Posted on Aug 09, 2012
I have aa 2007 chev her with 2.22 liter some of the fuses don't get power and some do on the fuse box block under hood everything to start and run car is dead
2007 Chevy her ? HHR ? 2.2L 4cylinder , check the run/crank relay ! Relay # 51 in the under hood fuse/relay box.
Power to many of this vehicle?€™s circuits are controlled by the module that is designated the power mode master (PMM). This vehicle?€™s PMM is the body control module (BCM). The PMM controls which power mode (Run, Accessory, Crank, Retained Accessory Power, or Off) is active.
Run/Crank Relay The run/crank relay control circuit is connected to a constant ground and is switched by the ignition 1 circuit or the body control module (BCM). The BCM, will in lieu of the ignition switch position, activate the Run/Crank relay during a remote start event. The Run/Crank relay supplies a power signal to the following circuits, when the a Run or Crank power mode is selected:
Automatic transmission shift indicator
Automatic transmission (A/T)
Switched power feeds to the BCM
Electronic brake control module (EBCM)
Electronic ignition module (spark control)
Electronic power steering module (EPS)
Fuel injectors
Powertrain control module (PCM)
Park neutral position (PNP) switch
Dec 22, 2015 | Cars & Trucks
2004. Why is the blower motor not receiving power?
The blower motor relay in the auxiliary junction box under the hood is good ? All relays ? only one controls the blower motor ! The electronic automatic temperature control module turns it on by supplying a ground inside the module ! The 30 amp fuse for the blower motor is located in the under hood auxiliary junction box ! At the relay socket test for battery voltage at pins 30 an 86 ,power form 30amp fuse ! The other two pins 85 an 87 ,85 is circuit to the electronic temperature control module . You could test this part of the circuit too , with a test light or volt meter . But if no voltage to the blower motor ,could be the electronic temperature control module is bad ! VEHICLE RELAYS Operation Diagnosis
Jun 11, 2015 | Lincoln LS Cars & Trucks
What is a control module
I small computer box that performs engine or transmission or accessory functions. for example: ecm electronic control module. or tcm transmission control module. or pcm powertrain control module. or lcm lighting control module.or bcm body control module
Apr 16, 2015 | Cars & Trucks
I have an Audi a3 99reg and the speedometer is no longer working but the rev counter and all other gauge s r working fine what could be the problem????
Check if your speedo counter is mechanical the is the cable either broken on the gear box side or behind the dash. If is an electronic one then check the electronic speed sensor on the gear box.
Good Luck Emma !
May 02, 2014 | Audi A3 Cars & Trucks
P0607 error code Triton V10
code p0607 refers to control module==fix is to replace the control module. No reference to what control module but codes around it all relate to the ECM.I would get another ECM that I know was working and replace it
Nov 08, 2013 | Ford Cars & Trucks
What is an ECM
Electronic Control Module, the engine management computer in plain English, the brain box in slang; some car makers call theirs an ECU (Electronic Control Unit), or a PCM (Program Control Module, or Powertrain Control Module), or ECM (Electronic Control Module). May even be other names for them. The engine computer uses several sensors (as inputs) to compute fuel requirements and spark timing (ignition timing) needed for the operating conditions at that moment, then it sends signals to controllers and switches (outputs) to run the engine at optimum efficiency.
May 23, 2013 | 2002 Mini Cooper
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Transfer case grinds truck only runs in 4wheel low nothing in 4wheel high or 2wheel drive
Manual or electronic t case?
Section 07-07: Transfer Case, 4x4 System, Service 1994 Bronco/Econoline/F-Series Workshop Manual
DESCRIPTION AND OPERATION Electronic Shift Operation The transfer case is equipped with a magnetic clutch, similar to an air conditioning compressor clutch, which is located inside the transfer case adjacent to the lockup collar. The clutch is used to spin up the front drive system from zero to vehicle speed in milliseconds. This spin-up allows the shift between 2-high and 4-high to be made at vehicle speeds listed in the vehicle owner's guide. The spin up engages the front lock hubs. When the transfer case rear and front output shafts reach synchronous speed, the spring-loaded lockup collar mechanically engages the mainshaft hub to the chain drive sprocket and the magnetic clutch is then deactivated. Shifts between 4-high and 4-low can only occur with the transmission safety switches closed. The vehicle's speed must also be within specified limits as determined by the transfer case speed sensor (3 mph or under). Electronic Shift Control System
This system consists of a two-switch control system, an electronic control module, an electric shift motor (7G360) with an integral shift position sensor, and a speed sensor. Switch Control System
There are two control switches located on the upper right corner of the instrument panel for fingertip shift control. The two switches are mounted horizontally and are identified as "4x4" and "LOW RANGE". Two indicator bar lamps are located in the instrument cluster.
When either of the two switches on the instrument panel control are depressed, the first thing that happens is that the electronic control module receives input from the transfer case shift position sensor to verify what position the transfer case is in (2H, 4H or 4L). Next, the electronic control module looks at the speed sensor and the park/neutral position switch or clutch pedal position switch (depending on transmission type). If all conditions are correct to allow the desired shift, the electronic control module will tell the electric shift motor to execute the shift. After the shift has been made and the electric shift motor is off, the control module again looks at the shift position sensor to make sure the proper shift has been accomplished. Finally, the dash indicator light and the pushbutton light on the control panel will be illuminated by a signal from the electronic control module indicating the desired function has been completed.
The electronic control module, located on the passenger side, controls the operation of the transfer case in response to inputs to the pushbutton control by the vehicle operator, the speed sensor, shift position sensor and the park/neutral position switch. Speed Sensor
The speed sensor, mounted on the rear of the transfer case , tells the electronic control module the speed of the vehicle to allow range shifts (in or out of 4L) to occur. Shift Position Sensor
The shift position sensor, an integral part of the electric shift motor , tells the electronic control module the shift position of the transfer case . Electric Shift Motor
The electric shift motor , mounted externally at the rear of the transfer case , drives a rotary helical cam which moves the 2W-4W shift fork and 4H-4L reduction shift fork to the selected vehicle drive position.
Nov 12, 2010 | 1994 Ford F250 Supercab
Where is the fuse box panel for a 1993 ford tempo
Access the fuse panel from the left of the steering column Relay Center Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Oct 13, 2009 | 1993 Ford Tempo
Pride Mobility Products Casual CL20KD Lift Chair  Chestnut  Logo
1,154 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
