Brother DCP 7020 LAser Printer. A t-shirt transfer was stuck and melted on the rollers. I dug out the pieces. Now it says rear cover open and I can't find a switch or sensor that might be pluged with paper or covered. Any suggestions?
  • 2 more comments
  • mkesselman May 02, 2010
    I switched off the power , unplugged the printer for 30 seconds then plugged it in and turned on the power. No change - the rear cover open display still present. There is no power switch to hold for 30 seconds... just an on/off power switch.
    I've removed the paper that was stuck on the heated rollers...tedious job but I think I got it all off.
    Where is this sensor I might reset?
    Brother DCP 7020 Laser Printer. Daughter put a t-shirt transfer through and it stuck to the rollers in the back that heat up. I was able to peel and scrape it off but now it says back cover open despite my closing it. I've tried turning the printer off and on and have looked for any wayward bits of paper. is there something else like a sensor to clean, reset, etc.?
    thanks
    I can't get into options. The Back Cover Open is still on and it beeps when I press options and won't let me in. Is there a sensor to reset or check in the rear door area?
  • 3,866 Answers
I would suggest Highly you call brother for a service manual because it will be hard for even us to tell you exact location of the sensor effected. I would also try what they call wet sheets they sale them at like Best buy with is ran threw that paper path to collect all the garbage left behind.
Other then that I would say have it serviced but you might be looking into some high cost for that but I would check into at east a estimate.
Thanks hope this was helpful please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 03, 2010
  • 666 Answers
Well after you do go in and make sure everything has bee cleaned our and check the rear cover make sure you go into options and clear the error count so the machine knows
hope this helps
Robb
Posted on May 02, 2010
    President:
  • 4,070 Answers
Hi! Please try this. Unplug the printer from power source then press and hold the power button for 30secs. while unplugged. Plug the printer again from power source then turn it on. This should reset the printer's system. Hope this helps and have a good one!
  • dj_relly999
    dj_relly999 May 02, 2010
    Alrighty, can you check the back of the printer if there is access for paper to pull out when jammed? The sensor might be detecting it and may need to be detached and re attached again.
  • dj_relly999
    dj_relly999 May 04, 2010
    Have you tried looking for the sensors? It is usually interconnected and wont normally function if its faulty.
Replacing pick up roller
you can safely replace the pickup roller without stabilising the document scanner and the laser scanner.
replacing the pickup roller is a relatively simple job that is easily done by someone who is good with their hands or with a little common sense.
here is a video showing the procedure
and a link to buy the part
Mar 28, 2014 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 paper jams
DCP 7020 PAPER JAMS SOLUTION1... LASER MOTAR DASTE CLEAN LASER MOTAR
Jan 16, 2013 | Brother DCP-7020 All-In-One Laser Printer
Back cover brother DCP-720 laser printer
Open the front cover, out of the cartridge, on the left is a direction knob, you should already be rotation in the end. You remove this side of the three screws, pull down the knob, adjust to the other side and then mount, screw....then ok....
BACK COVER
Sep 10, 2012 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Where is the drum located in the printer?
The drum unit is attached to the toner cartridge for the DCP-7020. If you open the front cover (flips down) of the printer, you need to simply pull the drum and toner unit straight out from the printer. You should place the unit on a large drop cloth or piece of paper to ensure that the toner doesn't spill. See chapter 6, page 12 (page 52) of the User's manual for the image of the drum unit. Page 6-19 has the removal procedure. You separate the toner unit from the drum by pressing and holding a lever on the left side of the unit. Then pull the toner cartridge straight out from the drum unit. The User's manual is available from Brother's product support page. The direct link to the manual is http://download.brother.com/welcome/doc000367/DCP-7020_UsaEngUsr_B.pdf .
I hope this helps.
Dec 12, 2010 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Keeps flashing back door open.
Got to be a little micro switch or sensor the is damaged or has gummy paper over it Have a good hard look
Apr 22, 2009 | Brother DCP-7020 All-In-One Laser Printer
Rear Cover message stuck on
First, try shutting off, and unplugging the printer to do a reset on the micro & logic circuitry. If you actually have broken switch or lever which actuates the switch, then an obvious solution is to replace said broken part. Or, if indeed a switch, you could possible bypass & defeat the switch so it doesn't sense the door open. If this is an actual mechanical switch bypass is fairly simple. You will need to find out if the non-fault (normal operation) condition is either an Open or closed switch and either short across the switch contacts (closed) or pull a wire off (open). If desperate to get the printer running, bypass the switch, use the printer, and get a replacement part ordered in the meantime, then install the new part to restore proper operation.
Jul 02, 2007 | Brother DCP-7020 All-In-One Laser Printer
26 people viewed this question
k24674
jasbo
jasbo
