Question about ASUS LCD Monitor
Hello, i have one asus lcd monitor, the display is good, but the display will rest only few seconds when i switch it on; I didnt understand what happends. Help me to solve the problem. I think the display sector functions good. only the Backlight sector is fault, how to replace the backlight sector? thanks for ur kindly response. senba
  • pcordi20 May 03, 2010
    thank you budmrtn, i see open transformer has problem. and i check the display with other power supply, it function good. and what is ur suggession?
  • 11,361 Answers
Please look through the pictures, most monitors have the same problem; bad caps, very few has failed lamp assemblies due to poor soldering works.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 03, 2010
Testimonial: "yes it is helpful, i will send the photos to you by mail. thankyou"
  • Bud Martin
    Bud Martin May 03, 2010
    Can you please send good clear pictures of the board, both side of the boards? Please also provide the model number.
    budmrtn@aol.com
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
I have a asus x58l and it has a black screen. cant see anything
http://www.asus.com/Notebooks_Ultrabooks/X58L/#support_Knowledge
Don't know why I did that.
Asus Support. Those two words don't even belong in the same sentence. (Neither does Toshiba Support, or Acer Support)
Notice the large statement?
NEED SERVICE?
(In otherwords GOT MONEY?)
Rant over.
Janet,
The problem will be;
1) Graphics chipset
or,
2) Video Cable,
or,
3) screen Inverter,
or,
4) LCD screen
I'm betting it's the economical, and easy to replace - screen Inverter.
Laptop on, shine a bright flashlight at the LCD screen of the laptop; and shine at various angles.
See faint images?
Backlight is out, or screen Inverter is out.
90 percent of the time the fault is the screen Inverter.
Moving on........
A) Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
The VGA port is on the Back of the laptop.
This is a General example of a VGA port (Connector), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for VGA Cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time; tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
(User Manual indicates not all laptops, may use the same Function keys.
Whatever Asus.
The Display Toggle-Over key has LCD on it, surrounded by a rectangular line. Has a small monitor icon to the right of it )
Display on external VGA monitor? No?
Hold the Fn key down again, and tap once more on the F8 key.
No display on external VGA monitor, indicates a problem with the graphics chipset.
Display ON external monitor, indicates a problem with the;
1) Video Cable,
or
2) screen Inverter,
or
3) LCD screen
Perform the 'flashlight test'. No faint images go on to the external VGA monitor test.
Post back in a Comment.
We'll go from there.
Regards,
joecoolvette
(There are NO service manuals available, to the public.
Thank Asus for that. To procede though can be done.
This will require a partial disassembly of the laptop, to include removing the Keyboard, and Palm Rest Cover.
Together we can accomplish this if needed.
May do something I never do, and that is because of no Service Manual available. May ask you to buy a replacement screen Inverter, and replace it.
Need other information above FIRST.
Average cost is around $25 to $30.
The plastic frame in front of the LCD screen is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and mounted to the bottom of the LCD screen assembly.
(Clip or a Philips head screw)
Average example,
http://www.ebay.com/itm/100-Genuine-NEW-Original-Asus-X58L-laptop-Series-LCD-Inverter-08G21VJ10107-/290873311574?pt=LH_DefaultDomain_0&hash=item43b9668156
Doesn't require removing Keyboard, and Palm Rest Cover.
DOES require removing all power. AC adapter (Charger), and Battery.
Mar 24, 2013 | ASUS Sabertooth X58 LGA 1366 Intel X58...
Hi, I have a asus VW192DR lcd monitor but it cannot open properly, only mixed colors, is there any chance that i can fix it on my own? pls help.
ASUS DISPLAYS are pretty FUZZY, HARD TO REPAIR but also HD and VIVID. ASUS DISPLAYS are usually HARD SEALED from the inside. Try paying it a rest and RESTARTING . Doesn't work? , DETACH the STAND to make it easy to work. The SCREWS to OPEN an LCD MONITOR are usually near the VGA/DVI/HDMI CONNECTORS. HOPE THIS HELPS.
Sep 08, 2012 | ASUS LCD Monitor
Lines at bottom of screen on asus x83v
Your lcd screen is going bad or your video card inside the computer is bad. To isolate the problem Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok then your video card is good and the lcd screen on your laptop is bad. If the Borrowed monitor displays the same lines as your lcd screen, then your video card inside the computer is bad.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 29, 2012 | ASUS X83VB-X2 Notebook
Cannot connect DVI in asus LCD monitor MS202N and the conputer
I don't understand why you cannot connect?
If your computer does not have a DVI connector then you need to purchase a DVI-VGA adapter.
Sep 20, 2010 | ASUS LCD Monitor
My computer monitor is black.
Try using the function key for your display options
You should see a key related to your function key, generally a different color then the rest, labeled (F, Fun, FN, etc...) then look for a CRT/LCD, or LCD, or a symbol of a rounded square, or something resembling a monitor or screen.
Hold Fn and press that button, give it a few seconds. It should switch.
You can also hold a flash light up to the screen and see if there's any image, if this is the case then parts need to be replaced.
Hope this helps.
Let us know
Good Luck
Apr 15, 2009 | Acer Aspire 5102WLMi PC Notebook
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
ASUS LCD Monitor Logo
415 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
