Question about Dometic Rooftop RV Air Conditioner
I have a Dometic Duotherm A/C with an analog thermostat control box (just replaced) and when the thermostat cycles the unit the fan shut down like its supposed to but the compressor keeps running
  • 4 more comments
  • Charlie Gibson May 02, 2010
    What is that? and what does it look like ? the only controls are in the box!
    The control box is the only control on the unit except an anti-freeze that connects to the condenser fins all other wires are to the capacitors it has no outside contacts
    The compressor does not reverse only ones that do that are heat pumps and this is a straight A/C
    The unit cools fine it doesn't need freon The unit works like a central unit when the thermostat tells it to, the whole unit shuts down, Its not doing that the compressor keeps running
    there is no relay all it has is the new control box
    Dont have one that i can upload to you only thing I can think of is the control is defective
  • 674 Answers
Do you have a schematic you could email me? nitensheaterservice@earthlink.net
Posted on May 02, 2010
  • Brian Niten May 03, 2010
    I think the compressor and fan run off the same contactor but if they don't maybe the contactor for the compressor is sticking.
    I was looking at the picture you provided and looking back at your posts. From what I can gather from them you're saying there are no contactors or relays outside this metal box that you replaced. I see in the picture there is a relay with a normally open connection (NO) and a common connection (COM). I can't tell if that turns the compressor on and off or not from the picture because it doesn't show what the wires from the connection labeled A/C connection go to. If you can determine where the wire on the #2 terminal go to let me know. With the unit not running you can check the voltage between NO and COM. It should read 115 vac. This means the contacts are open. Next start the unit and read voltage between NO and COM. It should then read 0 vac because the contacts will be closed and there will no potential difference between the 2 points. Remember though that it will still have 115 vac on it there just won't be any voltage dropped between the 2 which is what you are reading. Next when the unit shuts off and the compressor is still running check the voltage between NO and COM again. If it is open it will read 115 vac and will not be what is controlling power to the compressor. If it is still closed it will read 0 vac and I think will show us that it is controlling power to the compressor. Let me know what you find. Also use caution so you don't get shocked!!!
  • 713 Answers
Hi,the problem you are encountering is as result of the fact that the relay switch that connects the wires to the compressor is bad and needs to be serviced or replaced,but i'll advice you replace the relay switch as a lasting solution.When you take your device apart ,you will find a switch attached to the compressor,that's the switch that needs a replacement.
Thanks and take care
  • Oyelade Gbenga May 02, 2010
    Hope you have seen the relay switch that needs to be replaced,
  • 2,335 Answers
It sounds like your A/C unit may require recharging.
If the pressure is low, the compressor stays on all the time because it is trying to compress the refrigerant.
I hope that helps.
  • 1,170 Answers
Depending upon the model of your air conditioner, this may be normal operation. Air conditioner will run the compressor in a "reverse" mode without the fan occasionally in order to heat the coils. This is done to defrost the coils. After the frost is gone, the fan switches back on and everything goes back to normal.
    Genius:
  • 1,354 Answers
Your compressor censer is not working propely chacge that
I have a issue with my 2 Dometic DuoTherm air conditioners. The rv is a 2014 Palamuno Saber 50 amp fifthwheel. Ok. They cool very well but at different random times the compressor shuts off while the fan...
how long a power cord do you have and what size conductors are in it. when a a/c shuts down do to thermostat reaching its setting then trys to start back up shortly the pressures dont have time to equalize resulting in high amp draw. if fans runs all the time instead of shutting off with compresser it will call for cooling fast. i have a 2003 cardinal with 2 a/c's the smaller one has a continous fan & the larger one cycles fan with compressor. i have power cord rated for 50 amps. 110 to 115 is still a low vooltage condition.
Feb 21, 2015 | Dometic Heating & Cooling
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
Can you replace Dometic 3107541.009 analog control unit with Dometic 3313192.000 digital control unit?
e-mail or call dometic support : (www.dometicusa.com) and make sure you give them the model # of your control box at ceiling assy and they will tell you if they will work together.
Jul 30, 2014 | Dometic 3107541.009 Analog Thermostat...
Does the fan shut off on dometic ceiling cover control model
that would depend on the fan setting of your thermostat
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
I have a DuoTherm unit on my 1989 Cross Country that only runs in the "low" position and shuts off after about 5 minutes. Won't come back on until about an hour later, then runs for 5 minutes or so...HELP!
Is the unit ducted with a wall mount thermostat? If so, then I would say that you need to check the thermostat. Remove the face plate from the thermostat, there should be 6 or 7 wires, depending on the model. With the thermostat set to high/cool, check for power at the yellow wire and the blue wire. Yellow is the compressor terminal and blue is the high fan. If you have no power at the blue terminal, then you have a bad thermostat. If there is power there, then you need to access the control unit in the air conditioner (remove inner shroud). Check for power at the blue wire at the control unit. If there is power, then you have a bad control unit. The unit is shutting down because it is freezing up in the low fan speed position. You can use a jumper wire on the thermostat to go from the +12 terminal (red wire) to the Hi Fan terminal (blue wire) and also the fan terminal (Either tan or orange, depending on the model). If the fan comes on, then you have a bad thermostat. If not, then you have a bad control unit or the high speed in the fan motor is out.
Hope this helps,
Jeff
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
89 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
