Question about Mitsubishi WS-65511 65" Rear Projection Television
I have a Tedelex Ec Rp 4389 Rear Projection with a convergence problem i replaced ic(stk392-560)with(stk392-570) and it is still the same i noticed that pin 10 of the ic only gets 4.5v is that normal
    Sergeant:
  • 418 Answers
Pin 10 should be at the positive convergence power voltage. The ICs run on a plus and minus voltage from a power supply. Usually +/- 15V to +/- 30V. (don't know this brand.) (not sure if -570 is replacement for -560; could be.) I'd look through main power supply for these 2 voltages. Ohm to pin 10, etc. Check PS fuses there.
Posted on May 02, 2010
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Toshiba Convergence
You have one or more bad convergence amplifiers. Best to replace both convergence output ICs as well as check low value resistors associated with them.
Oct 16, 2009 | Toshiba 42H83 42" Rear Projection...
CLASS HD Convergance ploblem
You need to replace STK ics which are convergence ICs in your tv
You can get from the link below
Click this link to get convergence IC
It will cost you $20-30 to buy these IC .
Jan 30, 2009 | JVC AV-48WP74 48" Rear Projection...
TN50X81 - one convergence IC runs hot...TV powers off after 5min
What was the STKs that was in set ? If 110s always upgrade to STK392-180s. If they were 392-560s go back with the same. they worked differently then the 110s 150s 180s
Nov 27, 2008 | Toshiba TN50X81 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Akai replacement parts
You are not likely to find the board easily, but you should be able to replace the convergence ICs relatively easily. Look at the board. Try resoldering the pins on the STK ICs. If that fails to resolve your problem, replace the ICs. There may be some pico fuses located close by or low valued resistors that may be open. Check for those as well.
Keep us posted.
Dan
Jul 23, 2008 | Akai PT5598HD 55" Rear Projection...
Toshiba 50HX81 50 in. RP
Change both convergence ICs STK392-110 you can get replacements at the following link and they provide free instructions with pictures so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | Toshiba 50HX81 50" Rear Projection...
Convergence concern
They are located right next to the Convergence ICs easy to spot. There are numerous identical resistors.Usually 1 or 2 will be open.
Feb 10, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergence /ic chips
I just did it myself and it ran about $80. Make sure you get the IC's (2) and I would replace the 12 resistors.
Jan 09, 2008 | Philips 60PP9202 60" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
246 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
