Microtek scanner 4800
The glass hass fallen and when scanning a hear a beep and the scan is stopped. The glass is partially fallen
  • 28 Answers
If the glass had fallen, it surely interferred with the scanning mechanism. The glass is just snapped in place, and maybe due to excessive pressure it gaved way.You can open it but be very careful as the unit is only held together with fragile latches that easily break. There are slots at the bottom, insert a flat screwdriver and push it gently sidewards. If the rubber belt is not broken, fasten the glass (maybe with some adhesive), reassemble and hope for the best. Good Luck
Posted on Mar 26, 2008
    Sergeant:
    Champion:
  • 329 Answers
Ohh.. there must be a problem with your scanner dude..
Scanmaker 3830 driver for windows 7
this helped me with my scanmaker 3830 on windows 7 and windows 8 64bit too
You can download: ScanWizard 5 version 6.63 Here: ftp://microtek:microtek@files165.cyberlynk.net/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7,8 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works., install the scan wizard, restart the computer
Jun 25, 2012 | Microtek scanmaker 3840
My s400 works with Vista but not Windows 7, I
It will work with win 7 but it is complicated.
Download driver from the Microtek website
extract the files to your drive
locate the setup.exe file where you extracted the files
after the driver is installed reboot the pc
Now for the fun part...
Once PC is fully rebooted plug in Scanner ScanMaker s400
Windows looks for drivers in “windows update” and the “preconfigured driver folder”
Windows cannot find a driver.
Close “Driver Software Installation” window
Open Device Manager
Device manager shows yellow bang next to “USB scanner” under “Other Devices”
Right click on usb scanner
click “update driver software”,
Click on “Browse my computer for driver software”
Click on “let me pick from list of device drivers on my computer”
Click on “Imaging Devices”
Click Next
Under Manufacture there is no Microtek
Click on “Have Disk”
Click on Browse
Locate ScanWizard 5 V6.63 folder
Locate Disk 1
Locate Vista
Locate X86
There is a list of INF files
Choose first inf file, “Mii_x86_004.inf”
Click Open
Click OK
Now under Manufacture two entries are listed, Microtek and Microtek Driver Team,
On the other side there is a list devices s400 is not listed
There is an entry for 4800 Scanner
Select it and click next
An “update Driver Warning” opens select yes
Window now shows successful driver update.
And the scanner is listed as 4800 scanner
Click close
Close device manager
Open Scan wizard program
Scanner works fine.
The scanner will not work nativly with windows scanning.
Nov 11, 2009 | Microtek ScanMaker s400
Microtek Scanmaker i900 made a few clunking sounds while scanning. Then once the scanning mechanism got to the back of the scanner it seemed to have gotten stuck and could not reverse. It bumps a few...
Is your lock/unlock mechinism underneath in the unlock position?
I have a scanmaker 4800 and am assuming ours have basic similarities.
Mine has 2 round magnets that are visible when the glass is removed.
Once they fell out of place when I took it apart and I had to reglue them in. Is anything in the pathway of your carriage rail?(I don't know what else to call it) but a little wheel on the right side slides up and down this rail and maybe one of those little round magnets fell out and is blocking it.
Jun 17, 2009 | Microtek SCANMAKER I900 Flatbed Scanner
Installation driver for microtek scanmaker 4900
Here is the link to order the driver, however you will need to enter your op system to get the correct one, since you have not entered it here. Please Note:
Turn off and disconnect your scanner.
Before you down load the driver, turn off all running programs including your security/firewall. Go to the the little icons on the lower right and click on them and exit or turn off all that you can. Download the driver to your desktop. It will be an exe file. Then click on it to install and follow directions.If you have not been instructed to connect your scanner during the setup, do so now.
When you are finished restart your computer.
Thank you for using Fix YA! If your problem is solved, don't forget to rate us. Thanks!
Aug 16, 2008 | Microtek ScanMaker 4800 Flatbed Scanner
Scanner Malfunctioning
Lines in the ourput could be because of dust on the glass, clean the glass. Dont use any solvent. Try and reinstall the software driver after removing the existing. Run Scandisk on the computer. Soem scanners cannot work continuously for long hours.
S. Mohan, Chennai
Dec 22, 2007 | Microtek SCANMAKER I900 Flatbed Scanner
Viloet corruption lines
A CCD and/or firmware failure - replace scanner.
Dec 07, 2007 | Microtek ScanMaker 4800 Flatbed Scanner
Microteck scanmaker 4800
N-Tek/Microtek Contest SP 4800 - Scanner à plat - Couleur - A4 - SCSI (Scanner
Nov 01, 2007 | Microtek ScanMaker 4800 Flatbed Scanner
Lines on scanned images
if the lense has dust on it how do i clean
Oct 29, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
No picture, scans coming out white
First reinstall drivers , If problem not solved go to ur provider to repair your scanner . Thank You.
Aug 13, 2007 | Microtek SCANMAKER I900 Flatbed Scanner
No image obtained on preview scanning or actual scanning
First thing to do is un install and reinstall the software. Then consider - what other software could be running the could conflict[A graphics program for example]is to try another software for scanning if available. The other thing to consider is the age of the scanner- if it is from the DOS era-95/8/ME- then it will like as not not run- there is a firmware problem. Scanners have a controller chip - DOS era devices are looking for DOS commands - and they are getting NTFS commands- various makers like Microtek tried driver fudges- but they did not work. It has to be a NTFS scanner for NTFS commands.
Jul 11, 2007 | Microtek ScanMaker 6800 Flatbed Scanner
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
