Question about Nokia 1100
Water has entered inside the mobile set. what to do ?
  • 229 Answers
If you didnot let it dry outside and you switch on the phone.then phone get short circuit through some wire. so if you didnot switch on the phone. then take out battery, simcard, memory card and let it dry under sun. Thanks
Tenzin
Posted on May 02, 2010
Testimonial: "The solution given by you was VERY HELPFUL since there was no necessity of any kind of tool at that moment of crisis. Thank you very much for your timely advice and help. madhu navale "
  • 450 Answers
You should take the phone to pieces and pick upp the main board
It will propably be full off oxide/corrosion.
put the mainboard into a bath off isoprophanol and let in be there for five minutes,
then use a tootbrush to wipe off all the oxide.
let the main board dry and mount the phone,
and the phone should start, when there is no oxide left that short circuit the phone.
Posted on May 06, 2010
Heating problem due to water enter
remove battery immediatly dry inside of phone and battery with hair dryer on a very low setting.might work doubt it mobiles and water don't mix never know you might be lucky
Jun 28, 2015 | Samsung GT-S6102 Galaxy Y DUOS - Unlocked...
Hi, I have a Wind Mobile Samsung SGH-T469W cell phone with IMEI# 358624030514041. Would you pls help me to get the unclock code for this phone and instruction how to do it. Any help is greatly...
You can get the Reliable cost Unlock code for the Samsung Mobile SGH T469 Wind or Gravity 2 insid Mobile at here
http://www.mobile-unlocker.com/samsung-sgh-t469-gravity-2insid-82/rs2wp9/ You can get the Free Unlocking Instructions there and Unlock it step by step,or get the Unlocking Instructions Below to Enter Code successfully in the Mobile Phone.
Samsung SGH-T469 Gravity 2(insid-82) Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Samsung SGH-T469 Gravity 2(insid-82) mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-T469 Gravity 2(insid-82) mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-T469 Gravity 2(insid-82) with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-T469 Gravity 2(insid-82) will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-T469 Gravity 2(insid-82) shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-T469 Gravity 2(insid-82).
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-T469 Gravity 2(insid-82) is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-T469 Gravity 2(insid-82).
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-T469 Gravity 2(insid-82).
Jan 17, 2011 | Cell Phones
To lock my 6301 I would like to set my own Security Code. How do I reset my Security code on a 6301? I have no idea what is the existing Sec. Code in the phone.
SECURITY CODE:
Security code is kept to prevent some one who steals the mobile entering into your mobile data and using it .
Once you reset the security code the data will be lost.
If it is lost nothing can be done. You need to flash your mobile at an authorized service center which will reset the mobile memory and also all the data inside the mobile will be lost.
Nov 21, 2010 | Cell Phones
I have nokia 5800 mobile phone i bought it in december 2009 but on 19 th august in rain fall water enter in my mobile phone. i continue using my phone the battery become very heat and now phone is dead the...
> the phone cannot be repaired for the water damage voids your warranty.
Try this:
Soak your phone in Rice for about 24 hours
rice acts like a sponge that drains the moist inside the phone.
and then if the battery is heating I guess.. moist is still inside of it..
For better battery performance purchase a new battery.
Sep 01, 2010 | Nokia 5800 XpressMusic Smartphone
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Overfills at all level settings and leaks onto floor. Can you help?
HI, the water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Oct 14, 2009 | Maytag Performa PAV2200
Headset setting not coming off not charging
it might be problem of IC inside the phone due to water inside it or dispatchment of IC ... go to the nearest mobile service centre n chesk it out
Sep 14, 2009 | Sony Ericsson K550i Cellular Phone
Un able to switch on the mobile
well you can buy a new board or a new phone
Dec 27, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Water rushed into my mobile set
Very simple... Great Great Chartered Engineer from delhi rkcec5@rediffmail.com suggests that 1) Remove battery immediately after handset gets water 2) remove all cards 3) put it in Dry Rice container after tying it in a netted fabric so that rice don't enter inside it. Even Nokia will hate to get the solution. Or put Molecular sieves all round- as rice and molecular sieves just absorb moisture. You may have to keep the phone for at least 4-7 days. Have patience. Don't ever try to put batteries meanwhile before completion of at least 4 days. Better 7 days. Send thanks at rkcec5@rediffmail.com
Feb 10, 2007 | Nokia 2100 HANDSFREE BOOM MIC Headset
Nokia 1100 Logo
96 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
