Question about Microsoft Xbox 360 Console
Disk tray will not open and lights #1&3 flashing.
Ok, long story short. Tried doing X-clamp fix after RROD. no warranty and lots of time... Re-applied new "arctic silver5" thermal paste After cleaning old compund vigorously and put everything together... Now the disc tray will not open and the lights flash immediately after start up and the fans will turn off.... Please help!!! Out of ideas. The system will not run
4 Suggested Answers
SOURCE: RROD
get a repair
Posted on Jul 24, 2008
SOURCE: Still get 3 rings after xclamp fix and applied arctic silver 5
Take your metal case, and drill holes big enough to fit 5m diameter x 16mm tall screws. Put them all up through the holes and add 3 steel washers to each post. then add 1 nylon washer. >>>make sure you do the penny fix or replace the thermal pads before you place your motherboard inside the case<<< Place your motherboard inside of the case ( you can use tape on the back side of the metal case to hold screws in place; may want to do that before you add washers) add 1 nylon washer then 1 steel washer to each. Take off microsoft's bolts from the heat sinks and re-apply a ssmmmallll amount of thermal paste (size of a piece of rice for the big ones). Attach everything and you will be good to go.
Penny Trick- Take 2 pennys, wrap them one way with electrical tape, then turn 90 degrees and wrap them again so no copper is showing. >>You will need 4 sets of 2 pennys<< Flip your motherboard over and peal off the white things with band-aid looking squares on top of them. Peal the band-aid looking squares off and apply your tape-wrapped pennys.
Note: If you do not have these puddy-looking things on your ram chips, Use some hot glue, not a lot though.
You may also need to "bake" your 360. When you are all said and done with applying and bolting things. Take your 360 and put everything in except the fan. Take the fan plug it in its spot, then lay it diagonally from its plug, ontop of the tall cpu heatsink. Turn your xbox on for about 15 minutes. Let it over heat good so it can reset itself flat. Turn if off and let it cool down for about 20 minutes. Put everything back together and enjoy your console as your paid for it! smile.gif
Posted on Aug 21, 2009
SOURCE: have an error code 0022 on my xbox 360 (rrod) out
just continue your game
Posted on Feb 07, 2010
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I have 3 red lights flashing and my disk tray gets stuck
when u have 3 red flashing lights its called RROD or red ring of death. u have a 3 year warrenty on that so just sent it in and for the disk problem, if u still have ur warrenty , you can just send it in so they can fix it.
Dec 08, 2009 | Microsoft Xbox 360 Console
Xbox 360
have a look on Ebay, for a RRod kit. Also look on you tube, this will show you how to fix it if your xbox is passed the warranty
Dec 05, 2009 | Microsoft Xbox 360 Console
Xbo 360, after 5 minutes, 2 rrod
I think it might be false orverheating too, or a dead GPU atleast. I can suggest replacing the graphics card since it sounds like you repaired the system yourself anyway. There could also be a problem with the motherboard causing the GPU error.
Jul 27, 2009 | Microsoft Xbox 360 Console
My xbox 360 reads dvds but does not read the games
Ok so two Xboxes: 1 with RROD and one with Disc problem...
1) RROD :- There isn't much you can do to fix this one. Call Microsoft at 1-800-4-MYXBOX to see if the 3 year warranty is still available for you console (it's 3 years + 90 days of RROD and E74 Error Warranty).
If you;'re out of lucky and your warranty is void, you can open up the console and under the cpu and the graphics card put this thermal solution (this is thermal solution and it keeps the cpu and gpu (graphics processing unit) cool http://www.newegg.com/Product/Product.aspx?Item=N82E16835202006&Tpk=ocz%20freeze
Watch this video on how to apply the thermal paste and how to open up the console. http://www.youtube.com/watch?v=wsz0lNJ6JrQ&feature=related
Or if you need a temporary fix (works temporarily...) you can do the towel trick.
2) Disc Error :- I have the same error. You can do three things.
A) You have to keep turning it on and off. Here's how... Turn it on, then click open tray then close tray ( keep opening and closing tray about 10 times) then turn the console off. Then keep repeating process for about 15-20 minutes and eventually the game disc will show up. ( I have to do this every time)
B) Make sure that this is covered by Microsof't's RROD warranty. Then some how get teh red rings on this console and send it to Microsoft. (Note: I am not held responsible for your actions.)
C) This is a lens problem. So go out to a store and buy a DVD lens cleanser. It's a disc that cleans the lenses of the DVD or the XBOX.
This took me awhile to type so please be nice and take 10 secs of your life to rate this solution.
Jul 25, 2009 | Microsoft Xbox 360 Console
3 red lights and green in the middle. have already tried the towel around it and that did'nt work.
what you have is commonly known as the RROD, or Red Ring Of Death. what this normally means is that your xbox 360's GPU, or Graphics Processing Unit, has over heated to the extent that it has warped the motherboard and desoldered it's self from the motherboard.
Here's a few tutorials on how to fix this. Keep in mind though, always send it in if you still have warranty. that's the best way to make sure that's it's done right.
Links: -Video of someone fixing the RROD.
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm -How to tell which problem you have and how to fix it.
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm -A tutorial for solving the RROD and fixing it.
Hope this helped
- Gadorach
Jul 13, 2009 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
How do i fix my boken xbox 360 it has the hidden error code 0102 (you get the hidden code by holding the sync button on the xbox 360 and push the open tray button 4 times while still holding the sync...
RROD fix should work read this description of the code-
0102 Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
Aug 05, 2008 | Video Game Consoles & Games
Xbox 360 games
and if you do try to fix it yourself, or you've voided the warranty ( by already opening it) make sure you DON"T do the " towel Fix " it will only make things worse. you need to do an X Clamp repair. It's simple. I had no experiance whatsoever.with electronics. and I was able to figure it out the first time I tried it. I did it three weeks ago and my X box is quieter than ever and it works fine. so serach on you tube " X Box 360 X clamp fix " and you should see what you need to fix your problem.
Aug 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
