Question about Nikon D80 Digital Camera with 18-135mm Lens
My d80 keeps reading error, i have tried adjusting lense and changing memory cards, don't know what else to try
    Champion:
  • Nikon Expert
  • 225 Answers
What is the error message? If it is ERR then ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go call Nikon digital 1-800-645-6689.
Posted on Aug 25, 2010
My Nikon D80 shows an ERR, what should I do? FYI...I tried turning the camra on, removing the battery and pressing the shutter button for 30 seconds. That didn't work.
It's possible that you need to format the memory card. Formatting is found in the camera set up menu scroll down to "Format Memory Card" and follow on screen instructions.
Formatting should be done after each time you download pictures to your computer. Not delete, as delete does leave some data behind and eventually clogs the memory card so new data can not be placed on it. Another possibility is that the card somehow has become locked I'll include a diagram. Also a new card needs to be formatted to the cameratri3mast_228.jpg it is going to be used in.
Diagram
Jan 27, 2011 | Nikon D80 Digital Camera with 18-135mm...
I've given up trying to remove the "err" message from my D80 . I've done everything that was suggested ! removed the lens , cleaned the lens contacts , removed the battery and added a new...
"ERR" is camera error. Two items to try:1/ remove battery while camera is ON while waiting for approx 30 seconds, press and hold the shutter release, insert battery and give it a go. 2/ if there is a camera hardware reset button try that with camera ON. There may be a firmware update on Nikon web site, but if you cannot read the memory card, you cannot install it.
www.nikon.com Choose your country/area and go to support
Dec 05, 2010 | Nikon D80 Digital Camera with 18-135mm...
Hi K akima...have followed your advice, but no luck. When I go to continuous mode, it only lets me shoot a single shot, the display briefly reads r 08 then returns to r 09 again. I`ve tried my other lenses...
nikon r09,r11, etc . it mean memory buffer of your camera. memory buffer is a temporary memory for your captured images before it store to memory card.
if r00 it mean, you can't take a picture, even 1 picture... that because the camera buffer memory is full.
the number of memory buffer will also drop if noise reduction on
Feb 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
Nikon D80 error message rEE
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
Problem in reading memory cards of NIKON D80
Some notebooks cannot read SD capacities of 4GB and above. The workaround is to use an external SD card reader.
NOTE: Please rate our help to keep this free service online
Apr 22, 2009 | Nikon Coolpix 5700 Digital Camera
Formatting the SDHC Ultra II 4GB in my nikon D80
It shows the number of pictures left, not the size of the memory card...
Mike
Aug 20, 2008 | Cameras
EEE Error
3 reasons u get an "err" msg are
1. lens aperature not at smallest stop (f22 for example) turn aperture ring to smallest aperture setting or largest number
2. No memory card, or card not formatted or the magnetic latch of the memory card is sensitive try closing it firmly , or try changing memory card may it is damaged by force pullout.
3. weak batteries (4- AA and 2- CR123)try changing them.
4. Try changing or taking out lenses.
i hope something work out for u lemme know
Jan 16, 2008 | Fuji FinePix S1 Pro Digital Camera
Nikon D80 error
The CPU contacts on the lens can sometimes get dirty and they can be cleaned by gently rubbing them with the eraser end of a pencil.   Be very careful to not get any of the eraser rubbings into the lens.   Also, when handling a lens, don't touch these contacts, as the sweat from our hands is not good on the metal.
Sep 23, 2007 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
256 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
