Steam will not connect I keep getting errors when I run it. Error Code: -336 Unable to connect to HTTP Proxy. Your proxy may be misconfigured or offline. Or sometimes: Error Code: -102 but it's the same description. This happened after I battled malwares, trojans and virus' I have spybot search and destroy, AVG and a few others that are not running. I uninstalled and reinstalled Steam, I even did all the stuff here: https://support.steampowered.com/kb_article.php?ref=7247-OPVB-9949 I can log on just fine from my laptop but on my desktop it isn't working.
  • thejzone May 02, 2010
    Wow, you fixed it in a second. Your first solution fixed everything!
    Thank you very much!
  • 977 Answers
Hi!
The solution for your problem might be a little complex, but, to begin with,
go to Internet Options (in Control Panel), then go to Connections tab. Click on LAN settings and uncheck the option "use a proxy server for your LAN...". Press OK on both windows and try connecting to Steam.
If it failed, next step will be to download and run .SuperAntiSpyware
Next, use LSP-Fix tool to remove any malicious Winsock records.
If it still doesn't work, download and run HijackThis.
Select "Do a system scan and save a log file" - then post the log here...
Good luck,
Pelu.
Posted on May 02, 2010
Panasonic viera tv. Connection error 007
My TV set is PANASONIC VIERA 32AS600 series. Received error 007, canot connect to wi-fi network. In wi-fi settings, change to MANUAL, check proxy settings: delete all letters/characters in proxy address (leave blank), proxy port is not critical. Check your connection. Good luck !
Jul 30, 2012 | Panasonic Televison & Video
Proxy setting 130
Exactly error: "Unable to connect to the proxy server
A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a proxy, but Google Chrome can't connect to it.
Here are some suggestions:
If you use a proxy server, check your proxy settings or check with your network administrator to make sure the proxy server is working.
If you don't believe you should be using a proxy server, try the following steps: Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed."
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Sep 19, 2011 | Google Chrome
Error 336 (net::ERR_NO_SUPPORTED_PROXIES): Unknown error.
Make sure that you have the proxy disabled in the lan settings: Top right wrench tool button --> Options --> Under the Hood --> Change Proxy Settings --> LAN Settings --> Uncheck use Proxy server for your LAN. Hit okay. Close Chrome, open it back up and see if that works.
May 04, 2011 | Google Chrome
Issue with your network configuration... Proxy not suported by Google network chek for proxy .. and desable it..
Oct 06, 2010 | Google Chrome
You can report this crashes to Google, and let the Google will answer this problem.
How to Report it?
By Clicking the link below
http://www.google.com/support/chrome/bin/request.py?contact_type=gccrash
Jun 02, 2010 | Google Chrome
Proxy Settings in Vista
You have to disable your proxy settings from internet explorer.
Open internet explorer.
Click on tools >> internet options >> Connections
>> LAN settings >> uncheck everything
and then click on ok >> ok
and then close internet explorer and check your outlook is working well or not.
Mar 29, 2010 | Microsoft Computers & Internet
Error 81003004.......unable to login error showing ; check network connection
May be your Network Admin/ISP blocked your messenger port....Please contact your network administrator.....if you use socks proxy please clear the proxy from network connection>Lan Setting>Unselect Use Proxy Server.......etc. or check the Connection Preferences in the messenger window and select Connect directly to the internet and save....All the best
Aug 02, 2009 | Yahoo Messenger
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Errors found:Code 8024402C Windows can't check for updates
Description:
The 0×8024402C error code occurs because an incorrect character exists in the proxy override settings.
Possible Cause/s:
1. Incorrect character exists in the proxy override settings.
2. A misconfigured Proxy/Firewall can cause this problem.
3. You are trying to access Windows Update using VPN. The website and Automatic Update may not function properly.
4. The corporate environment does not have autoproxy implemented.
5. Your workstations sits behind a Microsoft ISA server.
Resolution 1:
Remove invalid characters from the proxy exception list and then clear the proxy cache:
1. Open Internet Explorer.
2. On the Tools, select Internet Options.
3. Click on the Connections tab.
4. Click on the LAN Settings.
5. Click on the Advanced button.
6. Please delete any entry in the Exceptions section.
Next, clear your proxy cache:
1. Click on Start, and then click Run.
2. Type cmd in the Open box to get a DOS prompt.
3. Type proxycfg -d at the command prompt, and press Enter.
4. Type net stop wuauserv at the command prompt, and press Enter.
5. Type net start wuauserv at the command prompt, and press Enter.
6. Now try the site again.
Resolution 2:
Reconfigure or update your firewall program:
1. Double-check the Proxy/Firewall settings. Add the following urls to the exception list within your Firewall/Proxy:
http://*.windowsupdate.microsoft.com
https://*.windowsupdate.microsoft.com
http://download.windowsupdate.com
Resolution 3:
VPN and Proxy.
Autoproxy is not picking up the wpad.dat proxy configuration file to determine the proxy to be used for the target URL. Thus we are going with no proxy!
1. Try to access Windows Update while not using VPN connection.
2. Use the proxycfg tool to specify a proxy server to use (proxycfg.exe -p <proxy server>). (contact your network administrator to find out the name and port of this proxy.)
This is every possible cause and solution for this error code and how to fix it. Please take the time to rate this Fixya for me for spending an hour researching every possible cause and solution for this code you posted for free, even if you don't figure it out. The solution to your problem is definitely here so read it carefully.
Jul 30, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
