Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
The bore fills with petrol? 'when i try to start the engine
    Brigadier General:
  • 4,088 Answers
The first thing you need to do is service and re-kit the carburetor. The lower chamber diaphragm is likely cracked and hard, and maybe the fuel metering valve is defective. Remove the spark plug, ignition off, and turn the engine upside down. With the throttle full on and the choke off, pull the engine through a number of times to expel the excess fuel. Check for a blue, snappy spark while the plug is out. Check for a plugged air cleaner and muffler. Hope this helps!
Posted on May 02, 2010
Testimonial: "thanks it was the metering valve"
MC Dies upon ANY throttle application. HELP!
Odds are that if it sat for a year with fuel in it, the carb may be gummed up. Opening the throttle will cause an immediate engine stop if it is not getting fuel.
I'd recommend a "clean out the carb" project, including using air to blow out allof the small orifices.
Jun 29, 2015 | 1996 Honda VT 600 C Shadow
Not starting
you have blocked the vent switch up you must not run and engine while filling up with petrol. can unblock its self around 3 days or so depends on how much petrol went up it.
Mar 07, 2014 | 2001 Volkswagen Polo Car Cover...
1992 Saab, Hello, My Saab ran out of petrol. I filled to half a tank but it still won't start. How to get this started?. Can i put petrol in the carburettor like a start spray, to hopefully boost and...
Hi Mark try spraying some starting fluid in the intake.You asked about putting petrol in the carburettor...your 1992 Saab has a carburettor? Impossible.That vehicle is fuel injected.Spray the starting fluid lightly or you'll flood the engine.
Oct 19, 2010 | 1992 Saab 9000
Mower blowing white then black smoke & running rough
if unit is ohv engine - i gather unit is using oil ?
may have a blown head gasket and air filter may be oil / petrol soaked
restrcting air flow
check oil level is correct ( and does not smell of petrol ) wet sumped and breather is working ( not stuck closed )
check for tight valve clearance
if all these are ok then might suspect worn rings / bore ?
may need further info on engine model - type
let me know and i will try help more if can
cheers
Aug 08, 2010 | Garden
I have a ford focus 1.8 diesel x reg 1999 girlfreind put petrol in it about 3weeks ago we have drained it all re fueled it and it started and run but now it wount start
poss the fuel filter has petrol in it,replace filter,turn engine over with fuel line unattached to clear lines then fire up,should be fine.you may hve a hot start problem for awhile but fill up with diesel at 1/2 tank to dilute any petrol left.in 32 years in the trade i have put petrol in so many diesel cars,and as long as it starts,keep it running,and start only when cold ish.
Apr 24, 2010 | 2000 Ford Focus
Wont start
charge battery, then check if you are getting a spark, remove the plugs and let petrol dry out of bores, if you are getting spark should start
Feb 27, 2010 | 2006 Triumph Speed triple
Chainsaw has a spark put petrol down bore still
Put some oil in with the gas to seal the rings into the cyl.
Also if the spark plug has black carbon on it.......it may not start.
If you have seen spark....did you check that with a spark checker?
Just because you see spark jump on the plug "out of the cyl "does not mean it will jump on the plug "in the cyl" under compression.
Oct 29, 2009 | Garden
Isuzu trooper starts briefly then dies
check your fuel delivery from the pump to the "dry" pulsing injectors leave the crank sensor alone! open the intake and, spray either (engine start) into the engine then attempt to start; it should start and, run until the either is used up then die. most likely your fuel filters are clogged
Aug 02, 2009 | 1992 Isuzu Trooper
Engine back fire
Hi ...... If problem continues try switching petrol off at the tap overnight or when you stop the bike. Sounds like petrol is leaking pass the petrol tap and sitting in the bores and exhausts, soon as you start it up it's igniting in the pipes. Remove the plugs and the colour will indicate how the jetting is set up.
Dec 30, 2008 | 1991 Suzuki VS 1400 Intruder
Put petrol into deisel tank
take of the fuel sender hose of tank and be prepared to catch any spills wen finshed fill with deisel
Oct 21, 2008 | 2003 Ford Focus
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
42 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
