Question about Zanussi 24 in. ZSF6150 Free-standing Dishwasher
Water is not heating
The water is not heating, could this be due to an element failure, relay failure or something else? How would I go about checking?
thanks
  • Anonymous Jul 19, 2008
    hi, I have the same problem but heater continuity is OK, however I found there was only 80v on supply to heater unit.Could someone please confirm that it will require a new PCB, Thanks.
  • rudgey11111 Sep 07, 2008
    dish washer DE540X works but does not heat the water
  • 185 Answers
You will have to ohm out the element if you have no continuityyou will have to replace it
Posted on Mar 25, 2008
F05 error code appears on the front panel and water will not empty but if i hold the waste pipe low into a bucket and the water then empties the cycle continues. machine is a hotpoint ultima wt900 1600...
hello there and thank you for choosing fixya
This is a verry common issue with these dryers Please read this solution fully below
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Jul 31, 2011 | Washing Machines
Have changed heating element, stat, but water still cold
Check and see if the replaced heating element has the continuity to the coils. If so the fault can be failure of the switch or the contactor/relay for the heater. Also the program controller must activate the relay to supply voltage to the coils. so check this line of supply to confirm.
May 12, 2011 | Dishwashers
Get error message F5 about 3 minutes into the cycle, have to reset multiple times to override
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
I have a service manual and some repair photos HERE
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-05 error
F05:
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Potential Causes
Check the Water Temperature Sensor, Heating Element and Element Relay • Check connections to the Sensor, Heating Element and Relay
Feb 05, 2011 | Washing Machines
My Miele G646sc dishwasher is not heating the water and therefore there is deposit of water at the end of the cycle. Please help.
Both the issues seems to be apart. The loss of heating is due to failure of the heating coil, failure of the heating coil control relay , failure of the program controller unit.
All of this must be checked with a multimeter only if you are able to remove and check the control panel of the washer.
Secondly the drain pump/valve can be clogged and is not fully exiting the water after the program comes to an end as the time given to pump out is not sufficient due to low flow - clogging with dirt.
Remove the drain hose/ drain pump and clean the filters , reset the valve/pump to test.
Jan 06, 2011 | Dishwashers
Washing machine code f-05
Hello there
Dec 26, 2010 | Washing Machines
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bosch dishwasher SHX46A -cycle runs too long (4 hours)- items still wet. The economy cycle also runs too long - should be about 80 minutes and it ran for 200 minutes.
It sounds like there's a problem with the dishwasher's heating element. The dishwasher uses the heating element to heat the water to certain temperatures, and it will wait (run for extra time) for the water to reach this temperature, and may eventually give up. When it's time to dry, the dishwasher uses the heating element to steam dry the dishes. If you're not technically savvy, you will probably need to have a pro work on the machine, but first check to make sure there's not hard water scale buildup on the heating element. If you're brave enough to work on the machine, you should check to see if the element's plugged in, check its resistance to make sure it conducts electricity, check the element's switching components, and finally the dw's computer board. There's a chance that the machine is just stuck in a loop or something. You should try turning off the circuit for a few minutes. There's a chance it may reset and start working.
Dec 07, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
Machine runs for about 5 minutes on normal cycle than stops and flashes f 05. It works on other cycles
F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
www.repairclinic.com
thanks.
Jul 13, 2009 | Whirlpool Washing Machines
Zanussi 24 in. ZSF6150 Free-standing Dishwasher Logo
200 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
