Question about Toys
Hi i have a futaba gy401 gyro with a s9254 tail servo, i had a crash and since then my tail servo constantly wags from left to right every time i switch on heli, i have tried putting the gyro on another heli with a different setup but it always does the same. you are able to operate the rudder to the left or right but the servo is still pulsing, thiese are very large pulses aprox 70% of whole travel. please help thanks nic
  • 748 Answers
Hi
If you put the gyro on another helicopter and have the same problem then you'll need to replace it. I've tried repairing these in my lab but just not worth the effort. Good luck
Posted on May 05, 2010
I recently rebuilt my trex 600, left the servos hanging, put it back together, and the S9255 front, left cyclic is not working. at all, no life is it repairable
Check the continuity in the servo motor from the board connectors (so it includes the wires) with a multimeter set on resistance - if it's not even registering then it's dead - the connectors have been ripped.
Nov 11, 2014 | Futaba S9255 High-Torque Heli Digital...
Have trex 450 v2 , with hobby wing ESC , two rudder servo burn up under two different transmit
have you got a digital or analogue servo in the tail. You have to select what type you are using on the gyro. If you use an analogue one and switch the gyro to digital, that will fry the servo for sure, iv'e burnt a hole in a servo case before. ( slap own face )
Jan 03, 2014 | RC Remote Control Rc Helicopter
Problem with servos burning up
Terry, look at my other answers about this, could it be another post by you? Digital and anologue tail servos need selecting on your gyro ;)
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
Regarding the BLS452: 1 What is the maximum (electrically driven) rotation? 2 What are the pulse widths for the maximum rotation? 3 What is the current consumption on 6V? 4 Is it digital, & if...
Some of the information you're requesting is at the following link.
http://www.helipross.com/futaba-bls452-brushless-ep-car-high-torque-servo.html
The current consumption will be dependant on the loading of the servo.
Digital Servos give and quicker resoponse to your input and provide a higher torque in a shorter period of time. Full explanation st the following link.
http://www.futaba-rc.com/servos/digitalservos.pdf
Jun 23, 2011 | Futaba Bls452 Brushless Ep Car Hi-torque...
2.4 radio problems
Hi
Call Great Planes service. There number is listed in the front of the Futaba manual.
Jul 08, 2010 | Futaba 7c Computer Radio Air R617fs S3152...
Throttle Problem
Hi
Your ESC is sensing an error. The error is either blade speed or a peripheral device - possibly servo or gyro. Sub the servos one by one. Check the blade tracking. Have you had any crashes lately? You should double check all the head assembly components.
Jun 02, 2010 | E-Flite Blade 400 3D RTF Electric Mini...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Copter spins c clockwise.
hi try fliking the switch on the gyro to rev or opposite to what it is now
Feb 18, 2009 | Esky Honey Bee King 2 RC Helicopter
Toys Logo
142 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
