Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Hi i have a kitchenaid superba double oven and trying to clean the glass on the bottom oven need toknow how to access the bottom ovens inside glass to clean it.
  • kevinspace20 May 02, 2010
    When I do the self cleaning it does not clean the inside of the glass panel. I am not referring to the part of the glass clesest to the food but inside the actual door. So the glass has drips of oil from the oven above going to down the glass.
  • 2,841 Answers
You will need to remove the door. Specific instructions for each model should be listed in your owner's manual. Once you get the door off a few screws are removed on the door bottom and inside of the door to allow access to then inner glass. Know that this door will consist of several panes of glass and seals. These seals must be installed correctly especially on a self cleaning oven. Go here: http://www.partselect.com/default.aspx?source=gawd&term=kitchenaid enter the model # and you can get a break down of the door and how it is assembled.
Posted on May 03, 2010
  • 1,555 Answers
Open the lower oven door.
Remove the bottom screw from each of the two side trim pieces.
To remove the side trim, pull the bottom out approximately 2˝, and slide the top down to free it from the control panel.
Remove the screws from the oven control panel.
To remove the oven control panel, pull it out at the bottom, and lift and unhook it from the oven cabinet support at the top.
Now you can access the door latch and unlock the door.
It would have been more useful for me if you'd have told me why you didn't used the self cleaning. Because in most of the self cleaning it stucks and the fuze goes bad.
Posted on May 02, 2010
I have a double KitchenAid superba built-in oven, but the lower oven doesn't seem to be able to warm up? Is there any way one can lock the use of the lower, or do I need to use the upper oven to activate...
there should be separate fuses for the top and bottom oven. check all of them if this is not the problem maybe your burner in the bottom oven is burnt.
Dec 09, 2010 | KitchenAid Ovens
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
How do you clean the inside glass on the oven door
You need to take the door off and apart. Glass is very hard to clean as the dirt bakes on it, so if you want it to look like new then just buy a new piece of glass.
Jun 05, 2010 | KitchenAid KEMC308 Electric Double Oven
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
I have a Kitchenaid Microwave/Oven Combination unit; something spilled from the microwave (which is on top) and fell through the slits at the top of the oven (which is below). The splatter is between the...
Same problem here
tried to access in between,
use of to much force and looks like damage will occur,
in use for one week now and it looks like regular maintenance, cleaning required between the double glass door,
going to return if there is no easy access and I don`t see it.
Sep 20, 2009 | KitchenAid Ovens
Stain inside double glass microwave door
most microwaves have screws on the top and bottom outer lip edges. or under the rubber grommet if it has this .
but this unit should have a 10 year warranty and they may cover this issue call them
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Feb 29, 2008 | KitchenAid KEHC379 Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Jun 02, 2007 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
107 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
