Question about Kenmore 73952 Gas Dryer
Elect dryer will not start after last load - Kenmore 73952 Gas Dryer
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 05, 2010
Hi I have a Simpson 4kg eziloader dryer that keeps tripping the power mains . Would this be the timer ?
The heating element uses the most power. Was the home wired by a licensed election ( the dryer plug)? if it was it should have #8 or #10 wire depending on the load. the breaker is sized to the wire (so don't change it). you may have a clogged vent pipe. this will reduce air flow and make the dryer work harder possibly tripping the breaker. You should probably start by making sure you vent is clear and free from debris, debris in the vent could cause a fire.
Sep 10, 2014 | Dryers
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
Changing belt maytag legacy dryer sde515dayw model
Have someone else look at the machine, I'm not sure about the last guy. Do smaller loads to ease up on the machine. It will last a lot longer doing more, but smaller loads.
Nov 29, 2013 | Dryers
I have had this elect dryer for about 3 years. Same prob from the start.. Takes forever to dry any load of clothes.. Litterally 4 plus hours to dry 5 bath towel and 6 or 7 wash cloths.. this is...
Long drying times can commonly be the result of improper or restricted venting.
Examine your vent hose. How long is it? Too many bends?
Check to make sure your vent hose is clear and free of an restrictions.
If vented outside, is the flap opening properly and free of lint buildup and is the hose clear?
Pull your dryer away from the wall and disconnect the vent hose, use a vacuum or brush to clean out the inside of the hose, sometimes shaking the hose a bit (if possible) will free any lint buildup that your vacuum or brush may have missed.
Don't overlook cleaning out the pipe that the hose connects to on the back of the dryer.
Lastly if you have a lint filter that's on the top like mine, remove the lint filter and check for obstructions there, use a lint filter brush and clean well, this is often overlooked and a major cause of poor drying, overheating, or fire.
Feb 11, 2011 | Dryers
I have a Kenmore 300 series elect. dryer that keeps tripping 30 amp breaker. Have already changed breaker wiring going from box to dryer and installed new motor.
Check your load/AMP capacity.
If you have other electrical appliances on ie. Iron, Heater, toaster, Kettle these will contribute to the over loading problem.
Old homes sometimes only have 40-80 amp capacity
Apr 19, 2010 | Dryers
GE Spacemaker Electic Dryer Poor Drying
Hello
Make sure you have a 30amp two pole breaker. Also, it could be a heater problem.
John
Nov 24, 2009 | GE Profile DPXH46EAWW Gas Dryer
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag Elect Dryer SDE4606AYW sounds like belt needs replacing
Go to www.repairclinic.com and enter SDE4606AYW. You will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly.
Jul 01, 2017 | Dryers
Kenmore 73952 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
