Question about Toshiba Satellite Pro L300 Notebook
Microsoft windows search indexer stopped working
I have windows defender whas stopped working, skype has stopped working and so on. around 4 programs has stopped working and I am unable to s=restore from a previous restore point
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 11, 2010
    Hello, This method is quick and easy, but may not work if you are having
    serious issues. Still it’s worth a shot before going to the other steps
    where you have to delete stuff.
    First, type Indexing Options in the Start Menu’s
    search box in Vista. Click on the Advanced tab and then
    click Rebuild. ou can also try clicking on Restore Defaults if Rebuild
    does not work. If for some strange reason you are not able to select
    anything on this page, you can rebuild the searcher index manually by
    editing the following registry key:
    HKLM/Software/Microsoft/Windows
    Search/SetupCompletedSuccessfully
    to zero and then restarting the machine. However, if you
    can avoid registry key modifications that’s best! Also, make sure to
    create a restore point before making any registry edits.
    Delete the Windows Search Index Program Folder
    If the above method did not work, you can try to delete all of the
    files associated with search indexing in Vista by deleting everything
    inside these folders:
    C:\ProgramData\Microsoft\Search\Data\Applications\Windows
    C:\ProgramData\Microsoft\Search\Data\Temp
    If you do not see these folders, you need to turn on viewing for
    hidden folders by going to Windows Explorer or My Computer
    and then choosing Tools,
    Folder Options. Go to the View tab and scroll down
    till you see “Show hidden files and folders“. You
    should now be able to see the ProgramData folder.
    Again, make a backup of the files in the directories
    before deleting them just in case, but they really are not that
    important. If you get an Access is Denied message when trying to delete
    the files, you will first need to stop the Window Search Index service
    by going to Control Panel, then Administrative
    Tools, and then clicking on Services.
    The service should be called Windows Search or Windows Searcher.
    Double click on the service and click Stop. After you delete the files, restart the computer and the index will be rebuilt and
    hopefully your error will be gone!
    Hope that helps someone with a very annoying error! Remember the
    search index service is not critical, so you’re not going to mess up
    your computer by disabling the service or
    deleting it’s files. Please let me know if you have any further questions or concerns. Thanks.
  • 32 Answers
When you turn your laptop on press F8
select Last Known Good Configuration
if it doesn't work need to do recovery
Posted on May 06, 2010
My storage is so full I am scared to get the fix it app
Hi, I Suggest not do delete Windows Defender and its now default antivirus/firewall provided by Microsoft. If you still want to delete it please do follow the below process to un-install manually.
1. Open a command Prompt and type the following to stop and then delete the Defender service:
  • type in : sc stop windefend and press enter
  • type in : sc delete windefend
2. Next you need to grant full permissions to and delete the following registry key so the Defender Control Panel entry can be deleted: open RUN command and type in regedit
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\{D8559EB9-20C0-410E-BEDA-7ED416AECC2A}
3. Also grant full permission and delete the Defender program registry key:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Defender
4. Now take ownership of and delete the following folders:
  • C:\Program Files\Windows Defender
  • C:\ProgramData\Microsoft\Windows Defender
  • C:\Program Files (x86)\Windows Defender (for 64-bit users only) and reboot the computer.
Nov 08, 2017 | YouTube Computers & Internet
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
How do i fix error ox800106ba
Hi Anon,
The 0x800106ba error may occur after Windows Defender is updated due to the computer's inability to update the Windows Defender firewall. It may not have applicable permissions needed for the update, or it may not have the files necessary for updating itself.
The Fix
Set Windows Defender to Automatic - You can set the Windows Defender service to Automatic, Disabled or Manual. Setting it to automatic might solve the problem. Follow these steps:
  1. Click Start > type services in the Search box > click Services in the Programs list.
  2. If you are asked for a Password before you continue, then enter the password > click Continue.
  3. Double-click Windows Defender, and click Automatic in the start-up box > click OK.
Uninstall and reinstall Windows Defender - If the first procedure did not help resolve the problem, try un-installing and then reinstalling Windows Defender. Due to the fact that Windows Defender is a Windows component, we will use AppWiz to un-install it from the computer. Follow these steps:
  1. Press Windows Key + R > type appwiz.cpl > Press Enter
  2. Click Windows Defender > click Remove
  3. Follow the prompts to uninstall Windows Defender
Let me know how you go!
Feb 12, 2015 | Microsoft Windows Defender
Google support
"Spyware" is a term used to describe software that advertises, collects personal information or changes the configuration of your computer.
Rogue anti-spyware programs are classified as "spyware."
These programs change your Internet settings and redirect your Internet searches to malicious websites.
For example, when you search for "Google," a rogue anti-spyware program might instead take you to a website selling rogue software.
Examples of rogue anti-spyware programs include Vista Defender Pro, XP Antispyware 2011 and System Restore.
Fortunately, these programs can be removed so that you can access sites like Google again.
Click "Start," then "All Programs," and then "Windows Defender" to open Windows Defender.
Click the down arrow next to the Help button. Select "Check for Updates." Windows Defender will install available updates. This may take several minutes.
Click the down arrow next to Scan and select "Full Scan" from the drop-down menu.
Windows Defender will scan your entire computer and automatically remove any spyware that it detects.
http://windows.microsoft.com/en-US/windows-vista/Using-Windows-Defender
Dec 15, 2013 | Computers & Internet
How to fix windows defender for free
The Windows Defender software constantly scans your computer for threats such as spyware that may slow down your computer or try to steal personal information. If the software wasn't installed properly or is conflicting with other programs running on your machine, Windows Defender may not work correctly. To repair the software you either need to download the latest update available for the program, or you need to completely uninstall and reinstall Windows Defender.
Restart your computer's operating system. Double-click the "Windows Defender" icon in the system tray at the lower-right end of the screen. Click the question mark icon at the top of the Windows Defender screen and choose "Check for Updates." Select "Continue" if you are running Windows Vista. Wait for the updates to finish installing and click "Scan." Click "Stop Scan" if the problem persists. Click the question mark icon again and select "Exit Windows Defender." Click "Yes" to confirm you want to close the software. Open the "Start" menu screen and select "Control Panel." Select "Uninstall a Program" in Windows 7 or Windows Vista, or instead choose "Add or Remove Programs" in Windows XP. Click the "Windows Defender" entry and select "Uninstall." Choose "Yes" and restart the computer after the program is removed. Navigate to the Windows Defender installation webpage (see Below). http://www.microsoft.com/downloads/details.aspx?FamilyId=435BFCE7-DA2B-4A6A-AFA4-F7F14E605A0D&displaylang=en&mg_id=10134 Click "Download" and double-click the Windows Defender installation file when it downloads to your hard drive. Go through the onscreen installation instructions. Open the "Start" menu and choose "All Programs." Select "Windows Defender." Click "Scan" to start a new scan for malicious software. Hope this helps
b>
Dec 27, 2012 | E-Machines eMachines Desktop PC
Windows defender not working
You might find some interesting security tips here.
http://support.microsoft.com/ph/11952
Hope this helps
Nov 28, 2012 | Computers & Internet
Some program are run automaticallly without opening them while i scanned my system and it shows no error............
  1. Open Windows Defender by clicking the Start button , clicking All Programs, and then clicking Windows Defender.
  2. Click the Tools button, and then click Software Explorer.
  3. In the Category box, click Startup Programs.
  4. Select the program that you want to prevent from running, and then click Disable.
  5. Click Yes to confirm that you want to stop that program from running.
  6. Repeat steps 4 and 5 for every program you want stop from running.
Dec 10, 2011 | Microsoft Windows XP Professional SP2
Microsoft Windows Security Essentials on my Emachine using Windows Vista Home on Start Up shows Windows Defender is turned OFF! I cannot get it to turn on manually or thru Control Panel
hi..you can only choose one antivirus program..usually when MSE is activated you cannot turn on windows defender..in any case that you had your system 2 activated antivirus it will affect the performance..
Jul 19, 2011 | Microsoft Computers & Internet
Remove Rahul Cool Virus and Autorun.inf Viruses
Download AVG, it is free, and it is probably the best virus protector around. It will clean your computer up.
Feb 03, 2010 | Microsoft Windows XP Professional SP2
Personal Antivirus has invaded my computer. I have went to several websites and learned that it is a scam and that they just want to sell me software. I cannot remove this through add / remove...
Kill processes:
pav.exe
unins000.exe
Delete registry values(go to run and type regedit):
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Personal Antivirus_is1
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_ITGRDENGINE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ITGrdEngine
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer "PrS"
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Personal Antivirus"
Delete files(use the search function to find files):
Personal Antivirus.lnk, Uninstall.lnk, pav.exe msxmlm.dll.tmp, drv1878004.exe.tmp,
Delete directories:
c:\Documents and Settings\All Users\Start Menu\Programs\Personal Antivirus
%UserProfile%\Application Data\Personal Antivirus
%UserProfile%\Application Data\Personal Antivirus\db
c:\Program Files\Personal Antivirus
c:\Program Files\Personal Antivirus\db
c:\Program Files\Personal Antivirus\Languages
(Where %UserProfile% is C:\Documents and Settings\Your username or C:\Users\Your username if you use vista)
reboot
Sep 19, 2009 | Microsoft Windows XP Home Edition
Toshiba Satellite Pro L300 Notebook Logo
211 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
