Question about Water Heaters
My water heater , Reliance electric 30 gal is getting the water wayy too hot and kicking out the red switch on the top thermostat. Is it the bottom or top thermostat going out ?
    Guru:
  • 351 Answers
Hi .. I would suspect the thermostats. If the bottom Tstat is not working then you would have just warm water. For water too hot, check the tstat settings, should be about mid scale. Check the mounting of the tstats, the back of the tstat must be in full contact with the metal tank surface. If the tstats are loose then they are not sensing the real water temperature in the tank and will overheat.
Posted on May 03, 2010
No hot water
It is probably the thermostat. I would suggest replacing that next.
Feb 24, 2014 | Reliance & 40 Gal Electric Mobile Home...
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Called and was told to change lower thermostat but yet again I had to go push red reset button on top panel to get it back on to get hot water. what should I do now?
You have electric water heater.
You have top and bottom panel, so water heater is 240Volt.
No hot water because ECO reset button tripped.
Water heater works correctly when reset button is reset, so electric power and circuit breaker are good. Water heater wiring is probably good.
Problem is most likely bad thermostat.
I usually replace both upper and lower thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problems continue after replacing thermostats, then test and replace elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Aug 05, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Reliance 501 model # 5 30 2srs4. I had to reset the unit after waking up to cold water. The water heated up in no time at all but the water was super hot. So hot it triped the reset button again....
No, the top thermostat will always heat first and then it should dwitch the power to the bottom one after the top of the tank heats...this is to get you hot water faster...
The top thermostat is bad and is not shutting off or switching....
Replace the top thermostat/reset combination and you''l be good!!
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 03, 2011 | Reliance & Lowboy& Electric Water Heater
Kicks off on high side temperature
one of the thermostats has gone bad and it causes the reset to kick...
Check out this tip and also the other links to tips at the bottom of this one...
Electric Hot Water Heater Temperature Adjustment
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
heatman101
Jul 12, 2010 | RELIANCE ELECTRIC WATER HEATER
Can this water heater be reset
Red button on upper thermostat just press it to reset.
Jun 07, 2010 | Reliance & 40 Gal Electric Mobile Home...
I have a reliance 501 electric hot water heater and i cant find the reset button. Where is it located?
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Jan 10, 2010 | RELIANCE ELECTRIC WATER HEATER
50 gal. Reliance electric hot water w/bottom element problems
Willard when you say it throws the reset button,do you mean the breaker on your fuse box of your home?
If you mean that then yes it could be a bad element.The bottom element takes all the abuse on a electric hot water heater. They can short out,and need to be replaced.
Dec 01, 2009 | Reliance & 50gal Electric Water Heater
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
