Question about Craftsman Nailer Kit, Palm Air Driver
My Primegrip nailer has broken; the piston part; I need it to be fixed
I have the parts for prime grip flooring nailer ...and we do fix them.
contact ; Dk 416 830 3046 Scarborough Toronto
Posted on May 23, 2010
Bostitch MIII FN drive pin is broken
The driver is held on the piston stem by a steel dowel/pin. There are nylon inserts on either side of the dowel to hold it in place. Pry the inserts out and press the pin out to seperate the driver from the piston stem. If you don't damage the inserts, you can reuse them. Bostitch recommends replacing them any time they are removed.
Feb 25, 2013 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch N60FN finish nailer only pops when the trigger is pulled.
replace broken driver, or if driver is not broken replace the oring on the driver piston
Sep 10, 2012 | Stanley Air Tools & Compressors
Cylinder is cocked in the chamber
by cylinder I take it you mean the piston, and if so you will probably need to replace the piston along with the chamber, it has probably scored the inside when it twisted or when you try and remove it. What I would do it remove the chamber with the cylinder and try and hit on one edge or the other to straighten it and then remove the broken part. You can download a breakdown for this tool at "dewaltservicenet.com" Let me know if you need more assistance.
Mar 30, 2011 | Porter Cable BNPN Brad Nailer And Pin...
Not firing right
the nail return spring for the piston is stuck or broken,dis mantle the gun and clean and check the spring to see if its broken
Apr 06, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Driver blade does not retract
if it is an air nailer, then its the return band or the o-ring on the piston of the driver. if the piston o-ring is worn or broken, then the air that pushes and pulls the driver just goes around the driver instead of moving it, if it is not the piston o-ring, then remove the cylinder and replace the broken return band, it is usually the bottom (sometimes wider) o-ring
Dec 01, 2009 | Air Tools & Compressors
Cooil nailer will drive one nail but piston will not return
it sounds like it needs a thorough cleaning to remove the asphalt and new o ring kit installed. The o rings are probably dry or worn and won't retract the piston, also look at the feed piston to make sure spring isn't broken, but I would clean and rebuild, its not that hard if you are handy with tools.
Nov 07, 2009 | Porter Cable RN175 Roofing Coil Nailer
CRAFTSMAN NAILER
I had the same issue with an older craftsman 351-18309 brad nailer and crown stapler. When I pulled off the top of the piston, there was a denigrated o-ring. I took an ear bud for my Bluetooth headset, cut it to size and stretched it to prevent it from holding the spring... And I'll be damned it worked! It both tools!!
/uploads/images/9_1_2014_6_12_26_pm.jpg
Dec 06, 2008 | Air Tools & Compressors
Bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Nov 18, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Nails won't shoot
18 guage nailer has a very thin driver and plastic cylinder which bends or breaks easily. Remove the head noting all the parts in the head and remove the piston which should be at the top of the cylinder. Check for broken or bent shaft. Most likely broken and jammed in cylinder. Parts are not expensive. Check WWW.toolpartsdirect.com for diagram and parts
Nov 17, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Craftsman Nailer Kit, Palm Air Driver Logo
299 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
