Question about Kenmore 22422 Top Load Washer
Leaking from the bottom
We just changed out the lid switch. Everything works good but water is running our of the washer on the floor from the bottom. What did we do wrong.
  • 5,911 Answers
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose when moving the machine around. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 02, 2010
Testimonial: "Your answer was very helpful. We opened up the washer and plugged the little hose back in and the water has stopped running out. Thank you, Thank you!"
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
It's quite possible that when you pulled or replaced the cabinet, you may have cut one of the hoses. I'd also make sure that the discharge hose is connected and that the end of the hose is above the water level in the machine. (I've done it myself)
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
My washer wont do anything!
It could be the lid switch, i had similar problem, changed the switch, helped for a day, changed it again, same...So then i did a diagnostic test. it said that it was the main control board,changed it ($135), didn't help. I noticed that was a little bit of water on the floor under the shifter, changed that, worked for a while, then i noticed that it was wet again. I traced it to worn bearings that the tub spins on which wore the tub seal and made water leak on the shifter electrical connection, Changed the bearing which is the whole transmission and comes with new tub seals. It stopped the leak and has been working for more than a year.
Mar 24, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 26842 Is leaking slightly. Small amount of water runs out from bottom of washer. What are the likely causes, how do I check, and what do I look for?
remove the two phillips screws holding down the top console,one on each side,if there is plastic covers on the end of the console remove the caps and then remove the screws.when you have the screws out flip up the console and with a screw driver pop the two clips and disconnect the lid switch harness closest to the right side clip,open the lid,grab the frame,tilt it forwards and pull back to remove the frame.now you can run it and see where the water is leaking from,if the washer doesn't run get a piece of wire,cut off the insulation off of the two ends and cut the wire around three inches,get the harness where the lid switch was plugged into,stick the jumper wire into the outside holes of the harness and the washer will run,the lid switch is just a safety,the manufacturer doesn't want the washer to run with the lid open so just jump out the lid switch,the middle hole is green and is the ground,just stick the jumper wire into the other two holes and the washer will run,check the pump and check to see if the tub seals are leaking,if the seals are leaking you'll see black dots one third of the way up from the bottom on all sides of the frame and the water will leak from the middle of the tub where the tranny. goes up into the tub,next time send the full model number,it will start with 110. or similar,also check all the hoses.let me know what you find.
Jun 04, 2011 | Kenmore 26862 Top Load Washer
Water leaking back into top drawer, resulting in error that prevents the cycle completeing
It is good that you identify the leak from the top drawer. Now it time to clean it. Pull out the tube. Near the bottom there is a squares tab on both sides. Press these tab so the tube could be pulled further out so you can lift the tube out of the rails. Push these rails in then you can lower the tube to the floor to dry out the wetness inside the housing. You can use the bottom drawer while deciding to fix the top drawer by yourself or call the F&P serviceman. If you decide to do your own then need to order the Lid seal with YOKE and a pair of actuators. THe original problem is the actuators,not holding down the lid seal so there was a leak. However, when it is bad it causes the lid tilted in one side then damages the seal from the lid. If you don't mind the time, when you replace the actuators keep original lid in until it leak the replace with a new lid. WHen change the new lid you have to change the YOKE since the replacement had a new design better than the original so they are different. Good Luck.
Dec 17, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 15, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Our Whirlpool washer won't drain
this machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Nov 11, 2008 | Whirlpool Ultimate Care II GSQ9669L Top...
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Whirlpool washer machine
I suggest you remove the front of the washer and observe the base of the drum and all hoses while in operation, using a flashlight attempt to find the source of the leak. **USE CAUTION!** Moving parts, water and electrical components present a very real hazard! If you have a top loading washer which agitates the clothing back and forth, one possible cause is the transmission. There is an internal locking mechanism which sometimes fails and will not engage, allowing the drum to continue to spin in one direction. The water will rise as the drum gains speed until it reaches the overflow outlets at the upper portion of the drum. These overflow outlets allow the water to spill out inside the bottom of the washer and out onto the floor. To check this, run the washer with the lid open (to do so, use a plastic or dry wooden stick [something non-conductive] to push down and hold the safety interlock switch closed) if the washer does not agitate back and forth and only spins in one direction you have a transmission problem. JUST BE CAREFUL WHEN OPERATING WITH THE INTERLOCK BYPASSED AS YOU WILL HAVE EXPOSED MOVING PARTS! If you feel any hesitation or concern about doing this...STOP!!, get someone comfortable or certified to do this type of work. While it is not difficult to do these things, there are risks and a momentary distraction can be painful, disfiguring or deadly. In this case, a repairman can be cheaper than a trip to the emergency room. You be the judge of your own skills and abilities.
Good Luck
Jan 30, 2008 | Washing Machines
Amana NAV5800 - How do I take off the lid/cover
Jon,
There should be two screws at the bottom of the front panel. Undo these screws and the bottom of the panel should swing out. The top will be held by clips or pins that will release as the bottom of the panel moves out. I suggest you lay a folded towel on the floor to prevent chipping the enamel finish when the panel drops free.
By the way, please ensure the machine is unplugged before you attempt any work on electric appliances.
Good luck
Bob Thompson (Australia)
Dec 22, 2007 | Amana NAV5800A Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Kenmore 22422 Top Load Washer Logo
128 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
