Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The agitator moves slowly and grinding
The agitator moves slowly and makes like a grinding noise like gears missing or not meshing
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER, an agitation problem can have several causes. Most commonly, this is caused by a broken motor coupling. The following link explains how you can diagnose the problem and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
I have included parts sources and instructions on how to replace any parts as well.
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Last of all, the most expensive problem that can occur, is a failed gearcase (transmission). The gearcase averages between $80 and $160 to purchase. If you wish to replace the part yourself, it is not that difficult. The following link explains how:
http://www.fixya.com/support/r3576575-replacing_a_gearcase_on_whirlpool_manufa
The procedure is rather lengthy, but not as difficult as you would think. It can save you a lot in labor charges.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the following part numbers you may need:
Motor Coupling 285753A
Agitator Cam Replacement Kit 285809
Agitator Dogs 80040
Gearcase 3360629
NOTE: If you replace the gearcase, replace the motor coupling as well. The sears website will sometimes offer a refurbished gearcase for about half the price of a new one. The part number will end in the letter "R".
If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on May 02, 2010
Grinding clutch
I'm a little confused on your description of the noise. If I understand you correctly It is making the noise when it shifts smoothly into gear but at the same time it makes a grinding noise ? It possibly can be synchronizers if the grooves on the inside of the synchronizers are worn bad enough to where the gear isn't slowing down enough causing a grind as the clutching teeth on the gear mesh with the synchrode and the shift collar.
If it is making noise in all gears except 4th you may have countershaft brgs failing. The power flow in 4th gear goes directly through the mainshaft and has a 1 to 1 ratio. All other gears the powerflow goes through the countershaft causing a load on the countershaft so if you have bearings failing in the countershaft you will hear noise in all gears but 4th.
i hope I understood you correctly .
Jan 18, 2014 | 2002 Subaru Forester
Agitator only moves a little bit and making noise
Most likely agitator dogs / gears are stripped out inside agitator. If it's a double action agitator where the top turns independently from the bottom, the top should turn one way and not the other. If top of agitator turns freely in either direction, then replace those dogs. If it's a single action agitator, then grooves that slide onto transmission shaft in agitator itself could be stripped out. If that's the case, replace agitator
Oct 27, 2017 | Kenmore Series 70 Washer Motor 387780
There is a tic-toc noise coming from my bike as I accelerate. Chain and sprockets are fine. Is this my shifting cam?
The shift drum would not make any noise, ever. The drum will outlast all of us. All it does is move clockwise and counterclockwise as the rider pushes the shift lever up or down as needed. Go to an empty parking lot or roadway and start out slowly in 1st gear, slowly gaining speed. Does the knock show up? Now go into 2nd gear and slowly gain speed. Is the knock there? Do the same for all the gears. If the knock is only in one or two gears the problem is a broken gear tooth. When the broken gear is replaced, also replace any other gear the broken gear meshes with. Whatever broke the tooth also put the same pressure on the meshing tooth. If the meshing gears are not replaced you will have the pleasure, ( and expense ), of doing the repair all over again when the cracked tooth on a meshing gear decides to break off. This usually happens within the first hour of riding the "fixed" bike. If the test shows no knock in the gears, then chances are the knock is a cam chain needing to be tightened. Please rate my answer. Thanks. tombones49_175.gif
Jun 14, 2011 | 2004 Suzuki GSF 1200 Bandit S
2nd and 3rd gear in transmission make a grinding noise
SOUND LIKE WORN OUT GEARS.GEARS WORN TO A POINT WHERE THEY MESH TOGETHER.INSTEAD MESHING GEARS GRINDING GEARS TEETH WORN WHERE THEY DONT MESH ANYMORE THEY ARE TEETHLESS.
Dec 31, 2010 | 1987 Toyota Pickup
Won't start. Harsh grinding sound from starter
Starter has teeth that mesh with teeth on the flex plate . most of these type grinding noises are do to missing teeth on the starter gear or flex plate missing teeth .Does your vehicle have a automatic transmission ? Have you had starter replaced lately ?
Mar 31, 2017 | 2000 Oldsmobile Silhouette
Washer makes grinding noise
many of the Maytags have had a problem with the pump bearing. This is what it sounds like. Tilt the washer back. Look underneath and take the belt off. The pulley on the pump is metal. try turning with your hand both ways. If it grinds that is problem. Let me know if need more info.
May 22, 2009 | Maytag Washing Machines
HP P3005 making grinding noises
this is a problem that HP refuses to acknowledges. Its caused by the gear that meshes with the main fuser gear..it wanders to the right as the printer prints. we are checking into a fix for this, since we are getting no cooperation for the manufacturer, Canon or HP. Canon makes the print engine
Apr 01, 2009 | HP Hewlett Packard LaserJet P3005 Printer
Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Jan 28, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
