Question about Garden
My flymo maxi trim 430 fires but won't run and just dies after a few seconds
If you have some starting fluid spray, a little into the carburetor and see if it runs. If it comes up but then dies, there's a fuel supply issue. Check for leaks in the tubing, a plugged fuel filter and be sure your carburetor is securely fastened to the motor. Any leak keeps it for sucking the gas into it. Your gas tank needs to have a vent to let the air in to replace the gas coming out but it usually takes a while for this to kill the engine so it'd be last on my list. Good luck.
Posted on May 03, 2010
Got a flymo maxi twin 430 two stroke, how do I get the idol screws in the correct positions so it will run?
Are you sure it's the idle adjustment screw or the carburetor adjustment screws? If it's the latter you'll need a specialized driver. They no longer have screw with heads a screwdriver will turn
Sep 15, 2016 | Garden
How do I remove the upper shaft of my flymo power trim 300?
It would seem to be one that snaps into place and isn't supposed to be removed.
Oct 19, 2014 | Garden
What is the basic setting for the two high and low screws on flymo maxi trim 430 carburettor
Most engines can be set at one turn out to get them started. Adjustments are then made to get the best results.
Apr 20, 2014 | Garden
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Hi Good Day I wonder if you could please help me, I have a Flymo Electrolux weed eater Power Trim 700, The cord holder where the plastic cord goes in is broken and I need to replace it, could you please...
Wendy, Have you tired going to www.flymo.com.
I went to that site and for the durban area, they showed three service centers. You might have more luck doing a search yourself because my geography of South Afirca is a bity rusty.
HTH
Dec 08, 2009 | Garden
No user manual
Hello:
Most 2 Cycle Engines use a 32:1 or 40:1 Fuel Mix Ratio.
The Newer 2 Cycle Engines use a 40:1 or 50:1 Fuel Ratio.
For Better Performance and to be sure you have Plenty of Oil to the Engines Internal Components, I Suggest (and I Use) a 32:1 Ratio in All my Equipment except for Post Hole Diggers.
Post Hole Diggers Use a 25:1 Fuel Ratio.
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Garden
Garden Logo
1,276 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
