Question about DFI AD77 Infinity Motherboard
I have upgraded to windows 7. I cannot use the
I have upgraded to windows 7. I cannot use the sata drive and it does not show up in the bios. It worked fine when I was using XP. DFI AD77 motherboard. Bios is Phoenix Technologies Ltd. 6.00 PG 02/13/2003
    Genius:
  • 1,189 Answers
“To install, and Update Hardware, click to open "Computer” from the “Desktop”, check to see if there is a DVD-RW Drive (D :), for external different (E or F:).
I. Look in the “Device with Removable Storage area,” see if the device is present, if so? Do the following: to “setup” the ('player') for “Installation.”
II. Right click on (DVD) “Media Player” select (“Install”) follow all instructions thereafter.
III. If the area is (Blank?), “go to,” and 'click' on the "Start button" click all “Programs” scroll for a Media Disk Player”, open, and do the (“same as above”) for the installation. *Note: “Do the same for “Setup” (above) “Install.”
“If this solution helped, ratings it is appreciated, thanks.”
Posted on May 02, 2010
Windows 7 installation disc doesn't see SATA hard drive
If your motherboard's BIOS is properly configured for SATA controllers and you burned the Windows 7 RC1 ISO image correctly, Windows 7 should recognise and install on a SATA drive without any third-party drivers. Consult your motherboard's User's Guide for assistance in setting up the BIOS properly.
In case Still Having Problem Then Follow Us For Computer Support For On : Computer Support
Feb 06, 2014 | HP Pavilion dv6130us Notebook
Win 7 not install in my pc mother board P4M800-M7 sata hdd not show
Hello here are the homepages:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=531&CategoryID=1&MenuID=16&LanID=9
Here are the other model ( version 3,1 )
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=548&CategoryID=1&MenuID=16&LanID=9
This is important when the drivers needed to be found.
But here seems to be no drivers for windows 7.
Here is only drivers for vista and xp, and there is absolutely no guaranty, the drivers will work on windows 7.
You need to setup the bios boot settings, in order to boot from the drive.
First boot device dvd drive, and second the harddrive.
This selection is urgent, when installing windows.
Other selections maybe needed, depending on the bios version.
The sata drive, should be shown in the bios main meny, when entering the bios.
I suggest you to download the manual, if you don`t have it, and read the setup install section, for basic boot procedure.
Best of luck
Feb 25, 2013 | Computers & Internet
Hp pavilion beep
Try setting the AHCI to SATA in the BIOS.
May 10, 2012 | HP Pavilion m8020n PC Desktop
3 drives, and win7 can only find one drive
Hi
You give no specification information about either the drives (SATA or IDE) or the computer.
If the hard drives are IDE, look at the jumper settings and ensure that the Primary drive is set to Master, and the Secondary and Tertiary drives to Slave.
You don't say if the Win 7 is a recent upgrade and all 3 drives showed in the previous operating system or if all 3 drives showed previously in Win 7.
See if Win 7 can see all the drives and the status of your hard drives in Disk Management:
Start > (Category View) Control Panel > System & Maintenance > Administrative Tools > Create & Format Hard Disk Partitions > Disk Management
Without more background information, this sounds like BIOS settings issue.
Enter BIOS by tapping the appropriate key POST screen (usually DEL or F2) and look to see if the RAID or IDE/SATA configuration settings are correct and try different settings > F10 > Enter.
If none of these solve the problem, look internally and check your hard drive data and power connections (it is easy to work inside a computer and forget to reconnect hard drive cables). Try alternative SATA or IDE cables.
I hope this helps.
Aug 28, 2011 | Computers & Internet
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
DFI AD77 Infinity Motherboard Logo
153 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
