Question about Ryobi Cultivator
Tiller tines move very slowly and with no torque. This is a brand new unit just put the first gas in the tank; engine starts and runs great just extremely slow tiller action.
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
8.50 Torque Rating Dual Rotating Tine Tiller: left old gas in tank and need to clean and start...
First step remove old fuel
Should be a turn off valve on bottom of fuel tank. Then go to the Carburetor were the fuel line runs to. on bottom is the float bowel. Remove the bolt in center of this bowel. drain old fuel out. Then turn on your fuel with bowel off. flushing the line. If not fuel runs out. Lightly tap the float. If still no fuel. Turn off fuel. Remove the float under the float is the needle and seat. Remove the needle if did not fall out. Clean or replace the needle. Then replace float and bowel. Turn fuel on check for leaks. remove spark plug check for spark. Should have a nice bright blue spark when you crank it. If so put a little fuel in spark plug hole. Give a pull. Or if you want dip the plug just to the end of threads in fuel. Replace plug . Should start right up.
May 18, 2010 | Craftsman 8.50 Torque Rating Dual...
My Sears rototiller will only start when I put gas directly in the carberator and then stalls out.
Sounds like you need to clean or replace your fuel lines. (Tubing/hoses) that model is pretty cut and dry with how its set up to pull start. Or maybe the gas in the tank is OLD? Try running a tube from a small can of fresh gas, to the carb. If it runs that's your problem!
May 02, 2010 | Craftsman 8.50 Torque Rating Dual...
My 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Aug 16, 2009 | Craftsman 8.50 Torque Rating Dual...
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Apr 09, 2009 | Honda Garden
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Ryobi Cultivator Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
