internet connection stopped, could get online before, now cannot when i ipconfig in command prompt all i get is : Windows IP configuration: no IP HELP frustrating
Check if the hardware (modem) is recognised in the device manager (icon my computer > right click, > properties, > hardware, > device manager).
if its recognised then right click it select properties and then select diagnise and see if your computer is communicating correctly with your modem.
If its there but fails to diagnise then goback to the device manager update the driver and try process one again.
if its there and diagnise well, then all you need is restart your computer after turning off other potential modem devices eg mobile phone connections or bluetooth, after restart try using your moddem once again (I am assuming you havent deleted any important files or change your settings.
If three fails, then restore your computer to an earlier time when you were still able to use your modem (start > all programs > accessories > system tools > system restore ) and follow the procedure that follows.
I have the siemens speed stream 4100 and I can't connect it in windows 7. How could I solve this...
(More)
I have the siemens speed stream 4100 and I can't connect it in windows 7. How could I solve this problem?
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to...
(More)
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to the laptop, now, the internet light will not come on. If I directly plug the modem to the laptop, all four lights are lit. When I plug in the router only three lights are lit. I have tried everything.
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light...
(More)
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light just continues to blink
