Question about SanDisk Sansa Clip MP3 Player
Computer sees mp3 as new harware mtp device will not open and run
Sansa mp3 don,t recognise mtp device even after downlading it . what may be the problem
Posted on May 18, 2010
Accidentally deleted everything on sansa e250 computer can't see device.
Hi there
I can understand issue. When you say the device is not detected. Then it could be an issue with the system files would have got deleted because of the format.
To fix this issue, i would recommend you to keep the device in MTP mode ( Menu->Settings->USB->MTP).
Connect the device to the computer.
It will give the message as Found New Hardware.
Go ahead and install the MTP drivers by following on screen instruction.
Then Unplug the device.
Restart the computer.
Connect the device.
Now we are offset and device will be detected.
IF still you have issue kindly revert..... Good luck
Feb 18, 2010 | SanDisk Sansa e250 MP3 Player
I am having problems adding music to my sansa mp3 player i plug my mp3 player into the computer a pc and it doesnt come up as it being in the computer
Hi there!
I can understand your issue. When you say having difficulty in adding the music in your player and the device is hooked up. Did you check whether the device is detected in the computer or not.
If the device is detected then go ahead and open the windows media player and add the music into it.
NOTE : Make sure the device should be in MTP mode, inorder to get the device detected in computer..
Please revert for further clarification..
Feb 17, 2010 | SanDisk Sansa e260 MP3 Player
Computer running under Windows XP says my device is not connected and yet it shows in Windows explorer?
Hi There..
When you say device is listed in windows explorer, butif the XP says device is not connected. Then i'd say the device is detecting as storage media (i.e MSC).
It needs to be connected as MTP. In this case i'd request you to update the MTP driver.
To update the MTP driver you can try two ways.
First Step:
1) When you connect the MP3 player to the computer you could see a SAFETY REMOVE HARDWARE on the system tray.
2) Right click on that safety remove hardware.
3) You will get a popup, in which you need to click on properties
4) That will bring the window in which you can see your MP3 player listed.
5) Right click on it and choose the option update driver.
6) This will update the MTP driver of the player and after that unplug the device
7) Restart the computer and now connect the device.
8) That will automatically update the drivers.
SECOND METHOD:
1) Go to device manager
2) Locate for the option that says USB and right click on it.
3) Try updating the drivers.
4) Now restart the computer.
5) That should work.
Kindly revert if you have any clarifications.
Jan 30, 2010 | Creative Labs ZEN V Plus MP3 Player
Computer cant open sansa clip
Make sure the lock switch isn't engaged.
Double-click My Computer, and see if there is a Sansa icon (some computers will only show it as a removable drive or an MTP device).
If the computer is not recognizing the player:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
Having problem adding this device to my computer
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
Dec 30, 2008 | GPX ML648B MP3 Player
Ilo 1GB 3.101.103 MP3 Player = MTP Device?
Uninstall MTP Device in System --> Hardware --> Device Manager
May 18, 2008 | iLO MP3 Player
My toshiba windows vista cant recognise my SandDisk sansa view
If "MTP" equals MP3, then open my computer and look for a new drive letter (in details view, You'll have to rest over the icons or click on them to show all details), if there is one that wasn't there before installing the player, then that is it.
Good Luck.
Feb 25, 2008 | SanDisk Sansa E280 MP3 Player
MY sansa e260 MP3 player
Try to add the device manually.
Plug the player in while it’s set to "MTP" mode. (This selection is in the Settings area)
On your computer, open Device Manager, and select: Add Hardware.
Choose the "already connected the hardware" option.
From list, choose "Add a new hardware device".
Select: "Install the hardware that I manually select from a list."
Select: Portable Devices, then MTP device.
Hope it works for you.
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
MTP device not found in XP with WMP 11
solve your problem from my post:
http://amritbera.blogspot.com/2008/11/mtp-problem-solved.html
May 22, 2007 | SanDisk Sansa e260 MP3 Player
MTP
Hi I am having a problem to with the MTP device. Bottom right corner of my screen has the window that says found new hardware...MTP device. I can not close out the window because it keeps coming back. Then I hear this like bubble sound when it's on the screen. Any suggestions? I think its for my new phone that I downloaded on the laptop. I am going to uninstall it and reinstall it and see what happens. Any other suggestions please let me know thanks...
May 02, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
SanDisk Sansa Clip MP3 Player Logo
102 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
